Monongahela
My 2014 craftsman yard tractor with tight turn capability has begun to throw the right front tire, repeatedly.
The entire tire assembly is held on the cast iron axle with a single retaining clip ring. That clip is isolated from the wheel hub by two washers. And the axle is protected from the wheel hub by two bushings (one interior, one exterior).
Recently the clip ring has begun to come off and allow the entire assembly, washers, tire hub and all, to completely separate from the tractor.
It seems the hub and washers are exerting enough outward force on the clip ring that it can not keep hold of the axle end. And once the clip ring is pushed off, everything comes off.
I've tried replacing the hub, the washers, the clip ring (multiple times) and keep everything thoroughly greased. The only thing I haven't changed out is the axle itself (which doesn't appear to have any damage on it).
I'm at a loss for why this clip ring assembly, which worked well for the first two years I owned this mower, doesn't seem capable of holding the wheel assembly on the axle.
Any recommendations, advice or insight into this problem will be greatly appreciated.
Thanks,
Mono
Thanks,
Mono
