Page 1 of 5 1234 ... LastLast
Results 1 to 10 of 50
  1. #1
    Member
    Join Date
    Jun 2013
    Posts
    31
    Redding
    New Holland
    Default Loader curl leak down
    Ok, I am a desk jockey who is a die hard DIY guy and loves his tractor time, so go easy on me, i have searched for an answer, but there is a reason i am confused, see below.
    I have a new holland tc24 and the loader bucket curl doesn't hold. It was slow at first, but now, it leaks down fairly fast, even with no load, you can watch it go fully down in less than a minute. The problem has gotten worse since i first noticed.
    Tonight I decided to try and solve it one more time before calling a mechanic...the problem is the same even when the lines are disconnected at the quick disconnect fitting. Not only does it leak down, but if I grab the bucket, I can lift it and get about half way up by hand. There are no visible leaks anywhere while doing this.
    Here is the confusing part...when the problem was fairly minor, I had the cylinders tested by the local hydraulics shop, they said they were in spec and didn't need rebuild...I think perhaps they got busy and didn't really test them or my problem has progressed?
    With the lines disconnected it's essentially a closed system right? And no oil on the ground means it has to be the cylinder that needs rebuild right?
    Thanks a million for the help!
  2. #2
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    15,983
    Central Ohio
    Kubota MX5100
    Default Re: Loader curl leak down
    You are correct. Just double check you are disconnecting the right lines. With the lines unhooked, that isolates the valve from the cylinders. With only the cylinders in the picture,and still drifting......cylinders are the problem.
    The issue is the cylinders are tee'd together. So you could have an issue with only one cylinder and still have the same symptoms. Good idea to just have both rebuilt though.
    Just curious, how many hours on machine?
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  3. #3
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,671
    Westminster, MD
    John Deere 4110, 455AWS
    Rebuilding both curl cylinders should cure your problems.
    KennyD
    www.boltonhooks.com
    #BoltOnHooks
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  4. #4
    Join Date
    Nov 2009
    Posts
    101
    Fowler In.
    Case Scatback 430 , International Cub , Toro GM72
    I had that same problem with my loader, it would go down just as fast as it went up and it was the seals. In my case it was just O Rings and shims and wiper seals at the cost of $15 for three cylinders. I think mine had been rebuilt with the wrong O Rings and were not ment to be in oil , who knows, but they came apart in my system which uses ATF type F . Loader curl leak down-dscf0441-jpg Not a hard job to do but messyLoader curl leak down-dscf0442-jpg
  5. #5
    Member
    Join Date
    Jun 2013
    Posts
    31
    Redding
    New Holland
    Thanks for the confirmation...There are about 350 hours on the tractor but it's about 15 years old. Previous owner didn't use it much, maybe 10 hours per year, i am getting closer to 100 per year. I got these really cool bolt on hooks I want to try, but the curl problem makes it difficult...thanks KennyD maybe it's time to try a new hydraulic shop if there is one.
  6. #6
    New Member
    Join Date
    Feb 2015
    Posts
    7
    Mount Uniacke, Nova Scotia, Canada
    TLB L39
    Quote Originally Posted by lexluther View Post
    Sounds like you have control valve problem where the H fluid bypasses the valve.
  7. #7
    Join Date
    Jul 2003
    Posts
    12,671
    Westminster, MD
    Quote Originally Posted by Little digger View Post
    The OP wrote this:
    So how is the valve the problem when the lines are disconnected?
    KennyD
    www.boltonhooks.com
    #BoltOnHooks
  8. #8
    Join Date
    Dec 2003
    Posts
    1,949
    Middle TN
    Kubota L4330HST
    I agree that a better hydraulic shop is called for. Re-test and rebuild then test as necessary.
  9. #9
    Member
    Join Date
    Jun 2013
    Posts
    31
    Redding
    New Holland
    Valve was what I was worried about as it is a more difficult repair. I tested leakdown with the lines disconnected, it seemed no different than when the lines are connected. When I was lifting the bucket, the lines were connected, but I think I could hear the fluid in the cylinder if that's possible with a 5 year old boy in the shop...
  10. #10
    Join Date
    Nov 2009
    Posts
    101
    Fowler In.
    When I rebuilt mine on the Case Loader I did not remove the hoses, I did not remove the cylinder from the loader, I removed the pin on the bucket end then the clip holding the head on the cylinder, used a piece of pipe 2 foot long through the hole the pin came out off and pulled the ram out. Remove the nut from the end slide everything off and start replacing all the rubber parts. I always take pictures of what I am doing every step so if it can go back together two different way I can look at the pictures and pick the right one and also share with someone that need a little moral support. I drove a desk for eight years and I enjoyed fixing or trying to fix things more then .
Similar Threads
  1. Curl leak on John Deere 4410
    By chief tom in forum Hydraulics
    Last Post: 07-21-2014, 03:11 PM
  2. no curl strenght on loader,
    By ddmargo in forum Kubota Owning/Operating
    Last Post: 04-01-2010, 10:21 AM
  3. loader curl
    By capt jack in forum Kioti Owning/Operating
    Last Post: 11-19-2009, 10:43 AM
  4. Kubota FEL LA681 Curl Cylinder Leak
    By vaughnd in forum Hydraulics
    Last Post: 04-15-2009, 12:11 AM
  5. Loader 'curl' is weak
    By California in forum Parts/Repairs
    Last Post: 06-24-2004, 03:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2016 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
