Results 1 to 4 of 4
05-06-2004, 02:02 PM #1Member
- Join Date
- Apr 2004
- Posts
- 47
- Tractor
- JD 990
1978 White/Oliver tractor 2-85 NEED HELP
This 2-85 had a 4wd unit added. I found the name Clark on the unit. The front right seal is leaking, are there any repair manuels out there for this front end?? Are there any speacial tools needed to change this grease seal??
Any hjelp would be apreciated.
05-06-2004, 02:16 PM #2
Re: 1978 White/Oliver tractor 2-85 NEED HELP
You might want to check the Hart-Parr Oliver's Collectors Association website. They have a forum there. If you are not a member of the "HPOCA" you should consider joining. For $25 you get a subscription to their magazine that includes a weath of information and parts sources.
05-06-2004, 07:20 PM #3Veteran Member
- Join Date
- Apr 2001
- Posts
- 1,656
- Location
- Cambridge New York (north of Albany, next to Vermont)
- Tractor
- Kubota L4630, with cab and loader, 1951 Ferguson TO-20, 1967 Oliver 1550 with fel
Ask that question on the Oliver Forum on
Yesterdaystractors.com
I have an Oliver 1550, and I've gotten a lot of great info there.
05-07-2004, 08:59 AM #4Veteran Member
- Join Date
- May 2000
- Posts
- 1,125
- Location
- Escaped to The Algoma
That would be the factory mfd axle. Check with your nearest AGCO dealer for the service manual.
