coachlarry
Member
Hey all
I have a Deere mower with a Yanmar 3tn** in it and its very finicky about air in the lines. The lift pump is completely buried in steel and hoses and might have an air leak. I used a hand transfer pump to bleed it from in front of the separator. It worked well, and the engine is starting smoothly at this time. I want to put a primer bulb or inline pump on this machine and am thinking about putting it after the separator just before the injection pump. it is a pretty short run, and can just handle a small pump or a primer bulb on right angles. Is this a good place for the pump or bulb or should it be in front of the separator?
