ETpilot
Gold Member
I went to start the engine and saw smoke coming from starter area. Visual inspection did not reveal anything. So I tried starting again and could hear starter still engaged. The solenoid may have stuck in the on position. I cut off the fuel to the engine but starter kept engine turning over. I had to disconnect the battery to stop the action. So now I have to remove the starter. The problem is I have the FEL attached and in the way making removal a bit harder.
So my question is, will I do some damage if I start the engine in this condition in order to slide the FEL about 3 feet to give me better access? With a friend's help I can do this in a minute or less. My fear is will I do any damage to the teeth on the flywheel? Not sure on this course of action. After the rain passes I'm going to test just the motor to see if the bendix is still engaged. Anyone have any helpful ideas on this problem? Thanks.
