Results 1 to 8 of 8
  1. #1
    Silver Member jclaudii's Avatar
    Join Date
    Apr 2012
    Posts
    104
    River Valley and South Arkansas
    MF35, Kubota7040, Case885, Ford 1100
    Default Help with finding Rotary Cutter Blade Bolt/Nut or Alternative
    I have an old Servis Sat6 bushog and when I pulled the blades and carrier off for inspection and sharpening earlier this year I noticed I need at least one new nut for the blade bolt as it has mushroomed. Servis is now owned by Rhino AG and as I was able to find some factory options. Funny thing is, I would think I would be able to locate a nut fairly easily but perhaps I'm not searching in the right places.
    Here are the blade bolt facts:
    3/4 inch bolt, LH thread 16 tpi, 3 inches long, one inch blade hole "flange"
    Here is a Kit I found, but I'm not sure about the company yet. This may be the way I go as 11 bucks for new bolts AND lock nuts is a great deal. Their shipping option is about 14 bucks though for two bolts LOL!
    BLADE BOLT KIT-SERVICE/RHINO | Rotary Cutter Supply
    a d
    Part #'s:
    Kit: B36107A2ALH
    BOLT# 125-908
    NUT# 5GL12160
    Nut Other - A-7A5512
    All attempts to find the kit locally have failed or even find it for a decent price. Any help would be greatly appreciated. I went to my local fastener (not fastenal) store and they sold me a nut that fit the bolt, but the markings on the nut a "i" lead me to believe it is Grade 1. It is also not a Locknut either.
    Thanks for the Nut Help. I'll get some pics to show the damage to the nut.
  2. #2
    Join Date
    Jun 2017
    Posts
    500
    West Chester
    Mahindra 2540
    Default Re: Help with finding Rotary Cutter Blade Bolt/Nut or Alternative
    Your nut is likely a grade 5, or "standard", bit of hardware.
  3. #3
    Join Date
    Apr 2012
    Posts
    104
    Here is the nut that was sold to me by my Local Bolt/Nut shop.
    Help with finding Rotary Cutter Blade Bolt/Nut or Alternative-20170825_084319-jpg
  4. #4
    Join Date
    Apr 2012
    Posts
    104
    Here you can see the Rusty Nut that has the mushroomed end. It appears to be a locking nut with two triangle looking indention's on opposite sides. The new nuts screw all the way on very easily and without a lock washer they may vibrate loose over time. Even with Locktite on this particular application I would be worried.
    Help with finding Rotary Cutter Blade Bolt/Nut or Alternative-1503668803780-jpeg
  5. #5
    Join Date
    Apr 2012
    Posts
    104
    I found this one but would need to be ordered at my local Fastenal store:
    3/4"-16 Grade C Yellow Zinc Finish Steel Reverse Lock Nut
    | Fastenal
    Grade C Lock-nut
    there is a grade G available, but it is very limited qty 3/4"-16 Grade G Zinc Finish Steel Left Hand Thread Reverse Lock Nut
    | Fastenal
    Or just bite the bullet and see how RotaryCutterSupply is even with there 15 dollar shipping on 10 bucks and 2 bolt/nuts.
  6. #6
    Join Date
    Jun 2017
    Posts
    500
    West Chester
    Mahindra 2540
    Quote Originally Posted by jclaudii View Post
    With properly applied Loctite I wouldn't worry. Heck, use red Loctite if you are worried—but you may need to heat it to remove it!
  7. #7
    Join Date
    Apr 2012
    Posts
    104
    Here is another supplier I found for a nut. about 7 bucks through my local farm supply store plus another 5 or so for shipping
    SMA - Your Farm Parts Source - 44-165237
  8. #8
    Join Date
    Apr 2012
    Posts
    104
    Just bumping this up for those who have more fastener knowledge than I. I returned the nuts I got at my local bolt/nut store. I'm hoping someone knows of another brand nut that would work like a woods, bushhog, etc.
Similar Threads
  1. Replies: 63
    Last Post: 02-22-2017, 08:47 AM
  2. Rotary cutter shear bolt
    By 9er in forum Parts/Repairs
    Last Post: 10-30-2014, 04:33 PM
  3. Rotary cutter stumpjumper nut??
    By countrybumpkin in forum Parts/Repairs
    Last Post: 05-27-2014, 01:33 PM
  4. tebben rotary cutter TC94-500 blade nut
    By mikeade in forum Parts/Repairs
    Last Post: 09-12-2013, 09:41 PM
  5. Rotary Cutter Blade Nut
    By ShenandoahJoe in forum Parts/Repairs
    Last Post: 04-06-2011, 10:39 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
