budepps3760
I bought a used post hole digger and the old man got over on me. What can I say, I am a softie.
A weld was broken because he used a grade 8 bolt instead ofa shear pin and so I ground it off and welded that. Gear box was empty and so filled that. One of the shields around the gear box is missing so I will need to buy 1 for that. However I am stumped pertaining to the 6 spline tractor yoke.
As you can see I inserted 3 shear pins to show you how the holes do not line up. The holes are also are not threaded . My question is how is this splined yoke kept attached to the PTO? I guess I could buy a quick disconnect tractor yoke from tractor supply or similar place but I would prefer not to sink another $70 into this implement if it's not necessary. Surely the previous owner was able to make this setup work somehow.
When I would lift the post hole digger up to its greatest height the PTO shaft would come off the PTO every time.
