Catsailr
I have a 2014 Emax 25 that got water contamination and had to drain fuel,replace filter and bleed and all was fine a couple of weeks ago went to use again and more water contamination so this time I dried out tank and replaced with fresh fuel, cleaned filter and dried as it was brand new and even though in contact with some water it looks fine. Re bled everything but not getting fuel at the injectors so I suspect fuel cutoff solenoid. It retracts when starting but stays out when in run position. I tried checking voltages at the connector and am only getting 5.4V in the run position on the red/wh. My question is there are two sets of wires running to that solenoid white and black on one connector and black, red/wh, pink/wh and black on the other. I have parts and service manual on order with Bill's tractor and am in need of schematic or knowledge of the wires going to the solenoid and what voltages to expect. I suspect the solenoid is bad but don't want to spend $200 if I don't need it. Thanks, Richard
