onionfmr
I am interested in synthetic oil answer. I forwarded it to the dealer and will see if they will do it. How many hours do you have now and what is your drain interval.
Has anyone else changed to synthetic?
I've got approximately 110 hours on the MF Permatran semi-synthetic transmission/hydraulic oil. I'll probably change it out at the regular recommended service interval in the manual. Somehow, I doubt that the tractor will make it that long as I'm guessing that this tractor transmission will probably fail before then. Switching to the semi-synthetic hyhraulic oil, IMHO is a bandaid to the real problem, whatever that is. I will admit that I haven't had milky hydraulic oil since the switch. There seems to be something wrong with some 1754, 1758.... HST tractors? I've read threads on this forum and others that individuals are having some issues with these HST tractors. Mine has reverse failure, others have no pulling power in other than the low range transmission setting, your transmission overheats. Mine has great pulling power! Pulling tree stumps, it easily spins tires in 4WD with the transmission in mid range. I've read where another individual can't break the tires free in wet grass in 2WD in mid range transmission trying to pull something heavy or do loader work. IMHO, I believe that there is something wrong with the hydro pumps on some of these tractors. Maybe, a cavitation problem that somehow contaminates the hydraulic fluid?
I'm wishing you luck getting you tractor fixed! Please keep updating this thread as you go forward. Looking forward to your update and fix. Thanks.
