Need help... john deere rear axle seals and bearing fell apart. I removed wheel and axle housing from tractor. How do i get the axle and final drive out of housing? I have tools. what do Ido next? Need help...
1948 Allis UC Hi-Crop Cane 1941 Allis WC 1948 Allis G with loader, 1948 Allis G with dual disc 1948 Allis G 1948 Allis G 1949 Allis G 1954 Allis G 1959 Ferguson TO-35 1972 MF 135 1979 Power King 2418 1989 Ford 345C TLB
I have PDF's of both tech manual for the 5520, shoot me your email if wanted
I am just curious because of questions that pop up here now and then; are the tires loaded and do you have wheel extensions to get the tires farther out from the tractor?
Welcome to TBN
After viewing parts schematic it appears one will need a special tool to remove "special screw"(key 19) from end of axle so planet pinion carrier can be removed from end of axle.
Key 19 is a lockplate for a standard bolt. To temove that lockplate you need to tightern that bolt slightly till that plate is loose .....then remove that plate and unscrew that bolt.
To reinstall tightern bolt to the correct rolling dragtorque ....then install lockplate and undo that bolt till it grips firmly on that lockplate
