Results 1 to 9 of 9
  1. #1
    Gold Member
    Join Date
    Aug 2015
    Posts
    481
    Maryland
    JD 4400
    Default Finding the right pulley
    I recently picked up a basket case Lesco commercial zero turn mower for cheap. Allegedly it had been sitting a couple years because the right hydro pump had died. They had the pump out already before I got it, and they couldn't find the pulley, fan, key, and nut to go with it. No big deal I thought for the price I paid. The pump looks repairable for about $40 in parts. Finally found what I believe to be the correct pulley through Cub Cadet PN 01006799 which sells for $100. I'm cheap (hence buying this POS in the first place) and I have another mower to use if this project lasts into the spring, so trying to find a cheaper alternative. The pulley and fan on the left pump is still installed, but that pulley could stand to be replaced due to some dents. $200 for pulleys seems a bit ridiculous.
    The pump shaft is tapered with a keyway. It measures 15 mm at the large end and 11 mm at the small end of the taper. Taper is 20 mm long, so that works out to .125"/in which matches SAE 744 pump taper shafts. The keyway slot is 4.75 mm. The threads are 3/8-24 right hand. I found a copy of SAE 744 JUN96 here but can't find a match to what I have. The tapered shafts threads jump from 5/16" to 1/2", so it seems some sort of oddball.
    This pulley from surplus center is the closest I've found googling, but it's out of stock and 1" larger diameter at 5.5" vs 4.5" on my machine.
    Any suggestions how to find the correct pulley?
    Attached Thumbnails Attached Thumbnails Finding the right pulley-img_20180214_002633-jpg
  2. #2
    Gold Member
    Join Date
    Jul 2017
    Posts
    344
    North Tx
    800 ford,MF65,Cub Lowboy,Farmall B,Ford 600
    Default Re: Finding the right pulley
    Mower repair business is slow right now so they might have time to contact their recources and make a few bucks. Call a mower repair shop and offer $xx if he can source one. Tell him you will pay before he has it shipped.
    We know the same pulley is used for a number of other applications,look's similar to main drive on a vertical engine lawn tractor. Contact the seller and offer $XX if they can find it.
  3. #3
    Gold Member
    Join Date
    Aug 2015
    Posts
    481
    Maryland
    JD 4400
    Can't find anyone real interested in digging deeper than a cross reference chart.
  4. #4
    Join Date
    Jun 2017
    Posts
    840
    West Chester
    Mahindra 2540
    For the one that you do have, but needs replaced, why not cut out the hub and weld it to a cheap steel pulley?
  5. #5
    Gold Member
    Join Date
    Aug 2015
    Posts
    481
    Maryland
    JD 4400
    Yes, that would work. I've considered that approach for both pumps if I can find any size pulley or sprocket with the right taper to cut the center from and re-weld into a steel 4.5" pulley.
    I believe the pump shaft conforms to a SAE J477 16-3 (A) for taper and keyway dimensions but not thread diameter (which doesn't really matter in this case). However, even with that info it's a hard thing to search because there are lots of SAE tapers and anything including "taper pulley" brings up thousands of hits on split taper pulleys and bushings.
  6. #6
    Join Date
    Sep 2013
    Posts
    1,357
    N. FL
    JD855, NH575E, Craftsman LT1000
    If you have the part numbers then put them in the search bar on ebay and change the sort method to lowest price and shipping first. I have done this with all the mower parts I buy and often find them for a fraction of the cost from a dealer.
  7. #7
    Gold Member
    Join Date
    Aug 2015
    Posts
    481
    Maryland
    JD 4400
    Quote Originally Posted by JD855guy View Post
    It's only about $10 cheaper each through eBay, so still $180 for two pulleys.
  8. #8
    Gold Member
    Join Date
    Jun 2017
    Posts
    333
    Mid-Central MO
    Massey Ferguson GC1720
    post your part #, I've a couple resources local
  9. #9
    Gold Member
    Join Date
    Aug 2015
    Posts
    481
    Maryland
    JD 4400
    Number is in the first post but I guess it's hidden amidst my rambling.
    Cub Cadet 01006799
    As mentioned, the mower is a Lesco Z2 60" which is supposedly identical to the Cub Cadet Tank M60. Used model 53AH5D8X750 to find the pulley number on partstree. As far as I can tell, the diagrams match my machine.
Similar Threads
  1. Diagnose"pulley" noise; R&R main pulley?
    By Moe Rocks in forum John Deere Lawn & Garden
    Last Post: 07-30-2017, 01:04 AM
  2. LT 1018 Electric PTO Pulley/Pulley Shaft Problem
    By cfkenney in forum Cub Cadet Tractors
    Last Post: 08-27-2014, 05:06 PM
  3. Z134 Water pump pulley and crank pulley do not line up
    By Gpops in forum Massey Ferguson Classic/Vintage
    Last Post: 07-23-2013, 09:14 PM
  4. where to get 4" pulley
    By toyocruiser in forum Build-It Yourself
    Last Post: 12-10-2003, 05:31 PM
  5. Need pulley for compressor
    By BILL_K in forum Parts/Repairs
    Last Post: 02-09-2003, 08:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
