Results 11 to 20 of 20
06-15-2004, 12:23 PM #11
Re: ROPS Pins
</font><font color="blue" class="small">( Hi...
How about welding "D" handles onto the current bolts ?
Dave... )</font>
I do have a question about that though. Does welding change the temper of the metal? Can it make it softer like regualr heating of metal can?
Cliff
06-15-2004 12:23 PM # ADS
06-15-2004, 01:06 PM #12
- Join Date
- Oct 2003
- Posts
- 482
- Location
- West-Central CT
- Tractor
- Kubota L3130, LA723 Loader, BH90 Backhoe, Curtis Cab, || '82 Gravely 8199KT garden tractor
Re: ROPS Pins
Hi...
I'd take it to a local welder/welding shop... they should know...
...and give you a price...
Dave...
06-15-2004, 01:20 PM #13Platinum Member
- Join Date
- Feb 2004
- Posts
- 652
- Location
- Hereford, PA
- Tractor
- LK3054
Re: ROPS Pins
You're not bashing - there is nothing wrong with expecting good design and execution. Where I work we design & manufacture industrial equipment - we're very picky on the design end, and so are the people in manufacturing. It's an attitude - those products are a reflection on us. When that connection to the customer is broken, the quality suffers.
06-15-2004, 07:00 PM #14Elite Member
- Join Date
- Mar 2002
- Posts
- 3,237
Re: ROPS Pins
I'm sure each hole is large enough for the pin and it's a matter of hole alignment. Remove the pin, loosen the bolts, wrap masking tape around the pin to make it bigger diameter, replace the pin, tighten the bolts, shim plates if needed. With tape removed, pin should fit freely.
06-15-2004, 07:58 PM #15Platinum Member
- Join Date
- Feb 2004
- Posts
- 652
- Location
- Hereford, PA
- Tractor
- LK3054
Re: ROPS Pins
It's a, 1-1/2" head bolt that is also the pivot - even if the tape did center and align it, there is nothing to keep it there. The first time you folded it it would change.
06-16-2004, 03:00 PM #16
Re: ROPS Pins
I have to push a little on the ROPS and the pin slides easily. I haven't tried readjusting those bolts, but it seems logical. I would NOT grind out the holes, as you might end up with a lot of rattles, I'd rather have tight pins...
06-16-2004, 03:43 PM #17Elite Member
- Join Date
- Apr 2000
- Posts
- 3,695
- Location
- Stowe, Vermont
- Tractor
- Kubota L3240HST, KX-121-3S
Re: ROPS Pins
I drilled mine out just slightly oversized so the pin would slide in and out easily, then tacked a big flat washer with a spring behind it to keep the pressure on. That virtually eliminated the rattle.
Pete
06-22-2004, 06:41 PM #18Super Member
- Join Date
- Oct 2003
- Posts
- 7,344
- Location
- Northeast, Ohio
- Tractor
- TC-40D SS New Holland
Re: ROPS Pins
I hate rattles..... [img]/forums/images/graemlins/mad.gif[/img]
When I got my New Holland I ordered a Firebird fiberglass canopy installed on the ROPS. The canopy seemed to aggravate the vibration coming from the folding ROPS mating with the removable pins. Fortunately I keep my TC-40D housed in my pole barn and it has 10 foot overhead doors. So I immediately removed the pins and replaced them with grade 8 bolts and nuts and tightened them down hard. It immediately eliminated the excess noise and vibration coming from the folding ROPS and I'm now a happy camper.
06-22-2004, 11:10 PM #19
- Join Date
- Aug 2002
- Posts
- 7,386
- Location
- North East CT
- Tractor
- 2003 Kubota BX-22
Re: ROPS Pins
The BX Series have a anti rattle knob that you tighten after you put the pins in. This eliminates all rattles. My was so tight going up and down, I never had to use them. They are good to hand your hat on though..... [img]/forums/images/graemlins/grin.gif[/img] [img]/forums/images/graemlins/grin.gif[/img]
06-22-2004, 11:53 PM #20
Re: ROPS Pins
My Kioti CK20 has the same knob at each pin. It's a nice feature to have. G
