manzie6887
I have a 1979 ford 1900 3 cyl diesel. It was running fine then died as if out of fuel. Plenty in the tank. Plenty in the filter. Cleaned the tank and filter and replaced hoses just in case. Dissasembled and cleaned injectors. Bled the system and it started only to die again after a few seconds. Took out the injectors after bleeding again and watched them all spray. It seems that if I bleed the system it will run for 30 seconds or so then die. Could my pump need a rebuild? Tractor has 350 hours on it but sat for a while. can I rebuild the pump myself? Thanks in advance for any help.
