Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Apr 2017
    Posts
    6
    Puerta De Luna, NM
    Yanmar 1500D
    Default Help. Does anyone know what happened here?
    Help. Does anyone know what happened here?-20180510_132801-jpg
    I have a Yanmar 1500D. Was getting ready to do a little maintenance and saw the right front wheel had this leaking from the inside. Can anyone help me identify the problem ?
    Thanks
  2. #2
    Join Date
    Dec 2014
    Posts
    1,562
    Armstrong, British Columbia
    Kioti CK27, 580 SuperM Case Backhoe
    Default Re: Help. Does anyone know what happened here?
    The seal is gone . Lift the wheel off the ground with the bucket and check for play in the wheel may need bearings as well.
  3. #3
    New Member
    Join Date
    Apr 2017
    Posts
    6
    Puerta De Luna, NM
    Yanmar 1500D
    Afraid of that. Where does the new lubricant go in if I can figure out how to replace the seal? Do you know if the seal set up is about the same on these smaller tractors ?
    Thanks for the help.
  4. #4
    Join Date
    Apr 2018
    Posts
    178
    Mariposa
    MF GC1715
    I would look for Yanmar manual online or go to dealer/parts site and see if you can find parts blow up diagram of front axle assembly and you can get idea what is involved... Or just be like me explore by taking it apart...
    Dale
  5. #5
    Veteran Member Kernopelli's Avatar
    Join Date
    Oct 2006
    Posts
    1,970
    Carterville, Illinois
    Mitsubishi MTE2000D, Dig It 258 Backhoe Deere Z930A ZTR
    Go to Yanmar Tractor Parts they have a parts diagram for it. They will have the parts you need and they are GREAT with help and advice.There should be a plug on top of the axle.
    Fill with 80-90w gear oil until its covering the axle shaft ( I dont have a Yanmar but it is pretty universal).
    Darryl
  6. #6
    Super Star Member Thomas's Avatar
    Join Date
    Apr 2000
    Posts
    17,514
    Lebanon,NH.
    Kubota L2800HST w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
    That's seal problem for sure,might as well do the other side since you got the tools out...hope you caught it quick enough so you don't have to replace bearings etc.
Similar Threads
  1. Oil & Fuel Can't Believe This Happened
    By Rockin' G Ranch in forum Kubota Owning/Operating
    Last Post: 08-26-2012, 08:44 AM
  2. what happened?
    By clemsonfor in forum Yanmar
    Last Post: 05-25-2012, 06:23 PM
  3. Has this happened to anyone else..
    By jd670 in forum John Deere Owning/Operating
    Last Post: 04-17-2010, 11:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
