Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    Join Date
    Aug 2002
    Posts
    7,386
    North East CT
    2003 Kubota BX-22
    Default Re: NEED HELP guys.JD 175 Will not spark!!!!!!!!!
    Take a jumper wire and clip it on the positive side of the ignition coil and put the other end on the positive side of the battery. Crank engine and if it starts, there is a break in the wire from the ignition switch to the coil. If it doesn't then you either have a bad coil or the points are burned out. Report back after you do this and we can go from there. What is the brand of engine and if necessary, I can send you to the correct engine group for further assistance.
  2. #12
    Join Date
    Mar 2004
    Posts
    19
    Im not sure which one is the ignition coil, If you are talking about the coil/mangeto that supplies spark there is no positive termilnal to that just ground and the ground at the coil has coniunity.
  3. #13
    Elite Member
    Join Date
    Oct 2000
    Posts
    3,056
    Windham County, Conn
    Ford 2120 , New Holland TN75D, Hitachi UH083LC Excavator
    In almost every case where I have had bad ignition on a small engine, it has been the points or condenser. You may have to pull the flywheel to get to them. They would have been the first things I would have replaced.
    Andy
  4. #14
    Veteran Member BillyP's Avatar
    Join Date
    Dec 2002
    Posts
    1,769
    Eagletown, OK
    JD 4610 ehydro MFWD
    The positive terminal would be the wire going from the coil/magneto to the condenser.
  5. #15
    Elite Member
    Join Date
    Jul 2003
    Posts
    3,373
    Goffs Corner, KY
    IH 2444
    The Kawasaki will have electronic ignition, do NOT cross 12 volts over on it or you will Fry it if not already bad. Sorry but that is all I know about it. Get a small engine repair manual that covers it , is my recommendation.
  6. #16
    Join Date
    Mar 2004
    Posts
    19
    Ok i called around to some JD dealers and we have come up with either the coil or most likely the Ignition trigger there both 50 bucks each Im goona replace the trigger this week and I will post back.Thanks for the help.
  7. #17
    Join Date
    Jul 2001
    Posts
    1,806
    Houston, TX.
    2001 TN65, 1951 8N Ford
    Polish the iron part of the coil that sets near the flywheel and the iron inserts in the edge of the flywheel that pass next to the coil with some emery cloth or sand paper before you buy any parts. One of my hands fixed his lawnmower that way today. I haven't bought a lawnmower in years, I pick 'em up off of trash piles and fix 'em and this is a very common reason for no spark.
  8. #18
    Join Date
    Mar 2004
    Posts
    19
    Well, I got it running, It was the ign trigger, 55 bucks from JD.
    Thanks again I wish I could figure out how to post a pic on here.
    Attached Images Attached Images
  9. #19
    Join Date
    Mar 2004
    Posts
    19
    I figured it out check out the tractor.I have ~260 bucks in it.
  10. #20
    Super Member Inspector507's Avatar
    Join Date
    Mar 2002
    Posts
    5,905
    Central Ohio
    Good deal [img]/forums/images/graemlins/grin.gif[/img]
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
