Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Elite Member
    Join Date
    Mar 2004
    Posts
    2,616
    Central Ma.
    Kioti NX4510HST
    Default Re: Is it the clutch?
    It sounds like your steering linkage is bent. Maybe you can bend it down a bit.
  2. #12
    Join Date
    May 2002
    Posts
    1,064
    Yanmar 1500D
    Ditto what Jim said. Something is bent or the wrong parts have been installed at some time in the past. Either the steering linkage or the clutch linkage. Nothing should ever touch the steering linkage through it's normal range of movement and it certainly wasn't designed that way.
  3. #13
    Join Date
    Jun 2004
    Posts
    69
    Western NC, Henderson Co.
    Kioti LK3054XS, Kubota B4200, MF 255, MF 50E
    Here are a couple of picture of the problem. In this one, the steering wheel is turned to the left, and you can see that the nut on the back of the steering rod is beginning to ride under the clutch linkage. The edge of the clutch pedal is just visible in the lower right corner of the picture.
    Needless to say, I've got some work to do to correct this problem. However, since this is not a primary tractor and I can get by with turning right, the repair job may have to wait until fall or winter.
    Attached Images Attached Images
  4. #14
    Join Date
    Jun 2004
    Posts
    69
    another
  5. #15
    Join Date
    Jun 2004
    Posts
    69
    Well, I finally got the time to tear down the tractor and find the problem. It was ultimately the clutch. The clutch plate was worn down so far that it had even begun to wear into the rivets. I'm in the process of putting everything back together now, so we'll see how the new clutch works.
    As for why the steering mechanism was rubbing over the cluch linkage, the best I can figure is that it must have been bent some time back. We have plenty of ditches and holes that could cause a problem like that. I know that it couldn't have been incorrect parts or work because the only folks that have ever worked on it have been my uncle and myself, and I can't recall ever doing any steering work.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
