Results 1 to 6 of 6
  1. #1
    Join Date
    Jan 2005
    Posts
    50
    Maryland
    Default Brakes Seizing- 1994 Ford NAA
    When I press the right brake pedal on this tractor, or even at times if I don't, the right wheel locks up and does not release until it is dragged along for a while. I'll pull the wheel and look, but has anyone else been through this? Could it be as easy as a missing return spring, or do these get a worse affliction?
  2. #2
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: Brakes Seizing- 1994 Ford NAA
    It's probably a '1954' NAA..Might just need to adjust the brakes and / or a broke brake spring.
    Soundguy
  3. #3
    Veteran Member GuglioLS's Avatar
    Join Date
    Feb 2005
    Posts
    1,119
    Edgewood, NM USA
    Jinma 354, 1953 Ford NAA Golden Jubilee, Komatsu Bulldozer
    Wow - Iv'e got a 1954 NAA Golden Jubilee TOO.
    Someting is broke off in there flopping around - as you say pull the wheel and take a look. Attached is from my shop manual.
    Attached Images Attached Images
  4. #4
    Join Date
    Feb 2005
    Posts
    1,119
    Edgewood, NM USA
    Here is Picture 2
  5. #5
    Join Date
    Feb 2005
    Posts
    1,119
    Edgewood, NM USA
    Part 3 of the manual
  6. #6
    Join Date
    Feb 2005
    Posts
    1,119
    Edgewood, NM USA
    4 th and final info from shop manual
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
