Results 1 to 9 of 9
  1. #1
    Elite Member Richard's Avatar
    Join Date
    Apr 2000
    Posts
    3,132
    Knoxville, TN / Jacksonville, FL
    Fullsized JCB Loader/Backhoe
    Default 2 stage clutch not clutching on stage 2
    We’ve got a IH-444 that sadly, is worse for it’s wear.
    I discovered the clutch was stuck from sitting idle for most of the winter. (peddle wouldn’t depress)
    Got it unstuck, fired tractor up, attached mower, went to cut field. Engaged clutch again to engage blades and got GRINDDDDDDDDDDDDDDDDD
    Upshot, it won’t disengage the pto using the two stage clutch. I put rpms down to about 3 rpm (as in three) which obviously isn’t accurate. None the less, I put rpm’s down as far as I could go, DID get blades engaged and cut field. Ok, so I jammed the lever in to engage the blades, there I admit it [img]/forums/images/graemlins/shocked.gif[/img]
    Obviously we have an issue.
    Any thoughts on how difficult/easy this issue might be? The clutch otherwise seems to be working fine. Just “part 2” of the two stage range.
  2. #2
    Elite Member
    Join Date
    Jul 2003
    Posts
    3,373
    Goffs Corner, KY
    IH 2444
    Default Re: 2 stage clutch not clutching on stage 2
    Richard,
    Check your clutch freeplay/pedal height first. Top of Pedal should be 6 inches off the deck with somewhere around 3/4 inch of freeplay. If this is ok the do the following.
    Take off the inspection plate on the bottom of the clutch housing. (4 bolts) There are 3 adjustment points to jack up some screws/studs to dis-engage the second stage of the clutch. I forget the exact gap with the clutch not depressed, but I believe it is about .080 or so, will check and reply back later.
    Get someone else to press the clutch while you watch what is happening, if the ends of the studs do not press on the tabs sticking out the second stage will not release. hint, it is in the center of the main clutch, well sortof....Adjust these 3 points evenly all around.
    Ben
  3. #3
    Elite Member
    Join Date
    Sep 2003
    Posts
    3,945
    New Brunswick, Canada
    Kubota L5030 HSTC, MF 5455
    Your machine may be old enough to start with the pto engaged until you get the 2 stage worked out. This may save your pto gears the gnashing you gave them.
    Not a good solution long term but maybe using it a bit will free up the 2nd stage of the clutch.
  4. #4
    Join Date
    May 2005
    Posts
    1
    United States
    Kubota L2850
    I have a Kubota L2850 that has the same problem, I can't locate the inspection plate on the right side of the flywheel housing, I think it is being blocked by the loader, when i need to use the pto I start it engaged. but when I get the chance I will remove the loader and check the clearence
  5. #5
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    6,257
    Eastern NY
    Case 885, JD 730D, Oliver 660 Ford 4000
    Maybe the PTO disc is stuck as well. Also, when the main (transmission) disc gets some wear on it, the internal adjustments referenced in the other posts get thrown out of whack, giving your symptoms. I would suspect the .080" figure mentioned is very close. New Holland and Ford compacts are around .060".
  6. #6
    Elite Member
    Join Date
    Jul 2003
    Posts
    3,373
    Goffs Corner, KY
    IH 2444
    Richard,
    Any update on this problem ?
  7. #7
    Join Date
    Apr 2000
    Posts
    3,132
    Several days ago, Uncle took tractor to a nearby guy who tinkers in his garage. he's supposed to get to it "soon" [img]/forums/images/graemlins/confused.gif[/img]
    I'll post results when I get them. My guess given age/general upkeep of tractor is the clutch just finally said no more.
  8. #8
    Elite Member
    Join Date
    Jul 2003
    Posts
    3,373
    Goffs Corner, KY
    IH 2444
    The clutch could be a goner. I thought mine was, but I was able to adjust the PTO stage and all is well now. My Tractor is a 2444 just the industrial ver of the 444.
    Ben
  9. #9
    New Member
    Join Date
    Aug 2012
    Posts
    1
    Oswego Ks.
    L2850
    I had the same with my L2850, I lost gears and I am in the process of replacing them now. The trans. pto disc was worn but the 2 stage looked almost as good as the new one. The tractor only had 1600 on it when I bought it so it may have been stuck. I show wear on the adjustment screws would that be that they need turned out? Any help would really be appreciated, thanks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
