Sarge
Replaced my 3rd power steering line this weekend ( In feed line). I believe the problem is the fact that there is only 2 bolts at the bottom of the column that attaches it to the floor/frame. Over a period of time with all the wiggling as you drive it tends to develop a lot of play in the column and a small crack develops in the line (usually where the fitting screws into the column). On the return line I was able to put hose between the 2 fitting using clamps to secure them, no luck with in line. My thought is to make a bracket from the column to the tractor about 1/2 way up the shaft to take the play out of it. Not much to connect it to though /forums/images/graemlins/confused.gif
Any Ideas??? It's a 9 year old Kubota B1700 and these lines are the only problems that I've had really.....
Sarge
Sarge
