Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Join Date
    Feb 2004
    Posts
    960
    15 mi. N. of Winchester VA
    Kioti CK30HST, Kubota BX-1500,
    Default Chains On
    Whew! 65lbs each! Still can't get those spring tighteners tight enough to do much, but the chains are on pretty good.
    Mike
    Attached Images Attached Images
  2. #2
    Gold Member jdgreg's Avatar
    Join Date
    Sep 2005
    Posts
    392
    Warrenton, Va
    Default Re: Chains On
    Chains look good. Where did you get the chains from? FYI, in the past I've used the black rubber bungee cords to take up the slack in my tractor chains, they work very well.
    Looks like you and I are gonna get hit with the same snow storm tonight. [img]/forums/images/graemlins/grin.gif[/img]
  3. #3
    Join Date
    Feb 2004
    Posts
    960
    Yes it does look like 6" or so of snow tonight and tomorrow for both of us!
    Chains were from www.tirechains.com. I have some car chains I think I can put on the front today.
    Mike
  4. #4
    Gold Member BamaRob's Avatar
    Join Date
    Aug 2005
    Posts
    465
    Alabama
    Mahindra 2615 4WD
    Please forgive a somewhat ignorant question from someone in a warmer climate. [img]/forums/images/graemlins/laugh.gif[/img] What's the purpose of the chains? Traction on ice? It seems that the lug tires would get pretty good traction in snow, unless maybe if it were hard packed snow.
    We don't get much snow down here. Maybe one good snow "storm" per winter with 2" or 3" inches accumulating. We have the occasional 10" snow, but that would be a once in a 20 or 25 year type event. We do get freezing rain more frequently which leads to very slippery conditions.
    Just wondering what the purpose of the chains was.
    Thanks,
    BR
  5. #5
    Super Member ronjhall's Avatar
    Join Date
    Apr 2000
    Posts
    9,808
    SE Michigan
    Kubota 2910 HST
    Five years and counting. [img]/forums/images/graemlins/cool.gif[/img] I have not installed my chains on my tractor for snow removal yet. [img]/forums/images/graemlins/blush.gif[/img] Its been a waste of money so far. [img]/forums/images/graemlins/tongue.gif[/img] Hope I never need them. [img]/forums/images/graemlins/wink.gif[/img] But then if I do__________. [img]/forums/images/graemlins/grin.gif[/img] Looks like I will get to test the need again tonight. [img]/forums/images/graemlins/smile.gif[/img]
    Nice set of chains. [img]/forums/images/graemlins/grin.gif[/img] I use a couple of black rubber bungee straps to keep chains on my snowblower tight. Easier to install than the spring type you have.
  6. #6
    Join Date
    Sep 2005
    Posts
    392
    Warrenton, Va
    Yes, they are great when snow gets packed hard/frozen and you get freezing rain/sleet on top of it, or iced over paved driveways. No kind of tires (even 4WD) will help when things are frozen/iced over, unless they have chains on. But, chains will leave scars on asphalt driveways (dont know about concrete, but probably so), dont ask how I know [img]/forums/images/graemlins/blush.gif[/img] . I wont use mine again, unless it's a last resort.
  7. #7
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,941
    Southern Wisconsin, USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    From the picture, looks like the side chains need to be tighter (shortened) by taking in more links. Extra links are cut off on the inside so nothing flopping around, and because the extra ones may be needed for tightening on the outside, they can be wired back so they don't flop (and bang on the fender).
    The springloaded cross tighteners look a bit flimsy, IMO and you may find that in deep snow and icy snow chunks, they will be ripped off. As mentioned, I sometimes add some bungee cords to take up some slop, but mostly tighten the side chains to take up the slack.
    Just an observation, and can take it for what it might be worth to you. [img]/forums/images/graemlins/wink.gif[/img] In icy conditions, chains are often a must, and the scratches in the asphalt get covered when the new sealer is applied. Deep scratches from getting 'unstuck' are harder to hide with sealer [img]/forums/images/graemlins/tongue.gif[/img] beenthere [img]/forums/images/graemlins/grin.gif[/img]
  8. #8
    Join Date
    Jun 2003
    Posts
    1,649
    Northern, New York
    Kubota L3830 03: RTV 900
    I have looked at the pic of your chains 10 times and still can not put my finger on what is wrong. Maybe nothing but they almost look like they are not wide enough for the tire.
  9. #9
    Platinum Member Varmintmist's Avatar
    Join Date
    Jul 2004
    Posts
    795
    Chicora, PA
    Mahindra3510
    It looks to me like you just need to put some tension on your spring tightners. Take another link or two on each until they are putting tension all the way around.
    Drive around a little and you will be able to take up some slack most likely, although a little loose isnt going to hurt at all.
    Chains will give a lot more traction than a rubber tire. The type shown also will give you lateral traction which is pretty handy on side hills. I run a less aggressive set all the time unless I am going down the road a fair peice.
  10. #10
    Join Date
    Jun 2003
    Posts
    1,649
    Northern, New York
    How would you like to put these on.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
