Results 1 to 5 of 5
  1. #1
    New Member bigroccrek's Avatar
    Join Date
    Dec 2005
    Posts
    8
    Pearblossom Ca
    TC29D & 1952 Ford 8N
    Default TC29 Wheel Weights
    I have a TC29 and I need some more weight in the rear. When I use the box blade and it fills up with dirt I have to engage FWD since the back tires tend to spin. I don't want to put water in the tires. I called the NH dealer and they want $400 for a set of weights(105 lbs) Are there any other manfacturer's wheel weights (cheaper?) that will fit the TC29?
    Thanks!
    Attached Images Attached Images
  2. #2
    Join Date
    Oct 2004
    Posts
    1,401
    Georgia
    Default Re: TC29 Wheel Weights
    Yes, there are some cheaper than that for sure!! I sent you a PM to give you an idea.
  3. #3
    Join Date
    Sep 2005
    Posts
    731
    West Michigan
    B3030
    If you can pull the box blade just by engaging 4wd, why do yo think you need more weight? You're getting the job done without it so why would more weight be better? Just curious, I may learn something here. Thanks.
  4. #4
    Join Date
    Dec 2005
    Posts
    8
    Pearblossom Ca
    Toolguy,
    As you can see from the pics I also have a ford 8n. I have had it for 15 years and it always met the needs, but I felt it was time for a newer tractor. I just don't think I should have to put the extra strain (using FWD) on the tractor to do road grading. Also, when I fill the bucket the Tractor gets a little light in the caboose.
    THanks
  5. #5
    Join Date
    Sep 2005
    Posts
    731
    West Michigan
    B3030
    That makes sense. The extra weight will definitely make the rear end feel more stable. Have you thought about loading the rears with fluid? It is a lot cheaper than cast iron. I have Rim Guard in the rear tires of my kubota B3030. Both dealers that I shopped said they always include the loaded tires when selling a tractor with a FEL. I know that your New Holland is a heavier tractor for the horsepower than the Kubota model that I have. Even so, unless you use it to mow lawn I think you will like more weight. On the other hand, I also don't think you need to worry about straining the tractor by using 4WD. They are designed for it. And I did notice tha 8N. Nice. I spent a lot of time on one them as a farm kid. Kid's today have dirt bikes, skateboards, BMX bikes, video games. etc. I had an 8N. I think the kids today are deprived. [img]/forums/images/graemlins/wink.gif[/img] Enjoy your NH. They are good tractors.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
