Frost Plug Heater Installation Question
   / Frost Plug Heater Installation Question #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
I got my frost plug installed. Now there's one problem...
It leaks!
I took everything apart again down to the frost plug and loosened the bolt and moved it around again to make sure it was in place. I tightened it back up and the leak seemed to stop. Then after I started the tractor it leaked again.
So here are my questions...
After a frost plug heater is installed, is it a bad idea to take it back out again to look at it? I don't know if the wings inside will bend back the right way or what.
Is RTV a bad idea in an application like this?
I'm pretty sure that I got the right size. I measured it four different ways and came up with 1 9/16" or 40 mm every time. It was a pretty tight fit getting it in too. I put clean antifreeze on the O-ring before I installed it.
What could have gone wrong? What can I do to fix it?
   / Frost Plug Heater Installation Question #2
The o-ring actually makes the seal. the heater should fit snug in the hole and you need to lubricate it before you push it home. I would recheck the o-ring to see if it might have been damaged if it is still leaking.
   / Frost Plug Heater Installation Question #3
Pictures!
Bob
   / Frost Plug Heater Installation Question #4
Rather than lubricating the o-ring, I used the Super-Blue automotive silicone sealant. The stuff seals anything except gasoline yet I've found it reasonably easy to remove when needed. 5 years and no leaks!
Here are the pics.
I still haven't taken anything apart yet. I decided to pull the tractor into the garage to make it easier to work on. I had to clean the garage before I could pull it in.
Hopefully today after I get off work I can get back into it.
   / Frost Plug Heater Installation Question #6
Just out of curiousity, did you use some light emery paper on the inside of the hole before installing the plug ? There could possibly be some crud or a small amount of rust that is causing that weeping condition.
I wiped it out with a rag, but I didn't use any kind of abrasive. Thanks for the advice. I'll do that on this second go 'round.
   / Frost Plug Heater Installation Question #8
If you have to take it apart again it might not be a bad idea to use a bit of emery cloth & some of the Super-Blue automotive silicone sealant like the others suggested.
If there's no harm in using the blue sealant, I might just loosen it up and put the sealant just inside the lip of the block heater. If I don't have to completely remove it, I don't want to.
   / Frost Plug Heater Installation Question #10
You can try that but if it's already wet with anti-freeze I wonder if the sealant will stick correctly.
2015 Mitsubishi Outlander Sport SUV (A53424)
2015 Mitsubishi...
Bryant 650AN048-E A/C Unit (A52377)
Bryant 650AN048-E...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
6 BENCH GRINDER (A53843)
6 BENCH GRINDER...
2011 Chevrolet Camaro Convertible Coupe (A52377)
2011 Chevrolet...
(INOPERABLE) INGERSOLL-RAND ROLLER (A53843)
(INOPERABLE)...
