Results 1 to 2 of 2
  1. #1
    Elite Member RobJ's Avatar
    Join Date
    Jul 2005
    Posts
    3,486
    Spring, TX (Houston)
    Kubota L2500
    Default Servicing manual steering
    As part of my weekend "what can I check on my tractor" schedule. I remembered to check the steering oil. Well I don't think there was any in there. After locating the standard 3/8" square plug (painted red at once), and removing that sucker 1 degree at a time (I needed a 3" wrench or remove another bracket), I filled and filled with oil. I figured I'd just need a top off so I didn't look at the bottle. I must have put in at least 6-8 ozs, It was dry. Still steers about the same but it's got some lube in it now. I used standard 80-90w gear oil. You can see the red plug just in front of the hose.
    And of course a pic for you!
    Attached Images Attached Images
    L2500
  2. #2
    Join Date
    Jun 2006
    Posts
    500
    20 miles southeeast of downtown Sacramento
    Kubota BX23
    Default Re: Servicing manual steering
    Fill it again when it stops leaking
    Kubota BX23, BT600 BH, LA210 FEL, Maschio L125 tiller, Gearmore BB 20-48 BB, King Cutter 6' rear blade, Homemade PHD, Brinly BST-50 broadcaster, ? 6' cultipacker, log & chain drag.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
