Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
  1. #11
    Platinum Member firemanpat2910's Avatar
    Join Date
    Feb 2006
    Posts
    901
    Havana Fla
    Ford 2910II
    Default Re: Bent exhaust pipe!
    since you are so close to the end of tail pipe anyhow, would the exaughst bother you if you just cut it off before the bend? If you angled the cut to blow down, or out to one side? This way its shorter and you can go back in the same spot and not bend it again . I couldnt tell from the pics if it realy needed to be that long. I shortened mine because it always blew in my face when hooking up the 3 pt pins.
  2. #12
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,624
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    At a minimum, I'd cut the damage out and use a flair to flair to sleave it back together with a sheetmetal screw in a couple places to hold the sleave in.. perhaps some muffler putty spread on the od of the pipe before pressed into the sleave.. or torch in a piece and then not worry about any small exhaust leaks that may or may not show up at the sleave.
    Bare minimum.. I'd cut it off at the restriction before further use...
    Soundguy
    Quote Originally Posted by Doc_Bob
    I have a horizontal exhaust pipe on my New Holland TN70A. I was backing up and it got caught on a piece of wood and bent the pipe and perforated shield on the pipe. So, any ideas on how to fix this thing? The replacement pipe costs 111 dollars. The tractor runs fine (maybe a bit quieter???) How much harm does this exhaust pipe restriction do to my turbocharged 3 cylinder diesel? The only reason I found that it was bent was doing my usual walk around inspection while I was taking a break. I had no idea it was bent.
    Bob
  3. #13
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    7,359
    Sacramento
    Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
    I will look again in the am, my first guess is 40%.
    Bob
    Gee, if this happened to me I would seriously consider rotating the exhaust system to the vertical position.
    My newly-acquired (last July) 1966 MF-135 diesel has a horizontal exhaust system. Don't like this arrangement for the hay farming that I intend to start next year. Possible grass fire hazard. I bought the adapter that changes it to a vertical layout. Cost about $20 for the adapter. Reuse the muffler and some of the exhaust pipe. Pretty simple and cheap fix.
  4. #14
    Super Member schmism's Avatar
    Join Date
    Jul 2006
    Posts
    5,096
    Peoria IL
    New holland TC(33)
    put me in the "just cut it off" camp .... (with the option to replace what you cut off if you dont like the results of just sliceing it off)
    Steve - TC33D 4x4 FEL, dual rear remotes with toys
  5. #15
    Super Member Farmwithjunk's Avatar
    Join Date
    Aug 2005
    Posts
    7,514
    Mt Washington, Kentucky
    Where do I begin.....
    Quote Originally Posted by flusher
    Another down side to that downSWEPT exhaust. If you leave the tractor running while hooking up an implement, you'll be standing in the exhaust while doing so.
    Another plus to vertical exhaust. With a muffler out in front of you, there's something knocking down cobwebs before they reach the operators station.
    My F-40 and MF 50 have the underslung exhaust (for now) Both have smashed exhaust pipes (for now)
    Reply to the original post. Turbo's deal with a LOT of heat. The'll do OK with the heat they're INTENDED to deal with, even a little extra. But a smashed exhaust pipe will create back pressure and trap heat due to not enough exhaust flow. I won't say it will DEFINATELY kill your turbo, but in any event, it won't do any good to keep that flat pipe. CUT IT OFF even if you don't replace it.
    There are three kinds of men;
    1.) The ones that learn by reading
    2.) The few who learn by observation
    3.) The rest of them have to pee on the electric fence for themselves.
  6. #16
    Elite Member
    Join Date
    Mar 2006
    Posts
    3,059
    Wisconsin
    2003 NH TN70A
    The tractor originally had a vert exhaust. My barn opening was too small for the vertical pipe, so I had it switched to a horizontal pipe. Now, in hindsight, I would have kept the vertical stack and just cut it short and then clamped it back on. Then I would unclamp it when I put it in the barn. But, no turning back now.
    Bob
  7. #17
    Elite Member
    Join Date
    Mar 2006
    Posts
    3,059
    Wisconsin
    2003 NH TN70A
    Quote Originally Posted by Farmwithjunk
    I actualy like the smell of diesel exhaust , in moderation.
    Bob
  8. #18
    Elite Member
    Join Date
    Mar 2006
    Posts
    3,059
    Wisconsin
    2003 NH TN70A
    Cripes, I had an idea this was not a good thing. I have no idea how long I ran the tractor with the smashed pipe. I never noticed any difference, but I was just doing some bush hogging with 5 minute spurts of 2300 RPM, then idle, then another 5 minutes, then idle for awhile, and so forth and so forth. Weather wa 60 degrees F. I had just changed to Rotella 5-40W synthetic before I used the tractor (I also changed the filter). Most it was smashed was 60 minutes. Such is life. Do I have a new turbo in my future????
    Bob
  9. #19
    Elite Member
    Join Date
    Mar 2006
    Posts
    3,059
    Wisconsin
    2003 NH TN70A
    Quote Originally Posted by AlanB
    I am in the muffler shop crowd as well.
    I would be suprised if it was over $30, and it would be perfect.
    Okay, here is the "plan". I ordered a new pipe from Messicks. I will dry fit the new pipe on to the tractor to make sure it fits. Then, with the new pipe in one hand and the old bent pipe in the other, I will go to a muffler shop and have let them use the new pipe as a template to fix the old bent pipe. Does this make sense?????? Then, I will have spare pipe to replace the new pipe next time I bend it (I know there will be a next time ).
    Bob
  10. #20
    Join Date
    Mar 2002
    Posts
    52,624
    Central florida
    Sounds like a good plan to me.
    Having spare parts is not a bad thing.
    I've had probelms with a hard fuel line on my NH 7610s before that have left me stranded. A new fuel line is only 20 some odd dollars. I DO have a spare setting in my parts bin, and have fixed the old one.
    Soundguy
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
