Results 1 to 10 of 20
01-05-2002, 02:39 PM #1Epic Contributor
- Join Date
- Aug 2001
- Posts
- 20,704
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Seating Small Tire On Rim
My new PT425 arrived and one of the tires on the snow plow attachment was flat. I could not inflate it, because it was not seated on the rim. PTRich suggested that I use a ratcheting tie down strap to squeeze the tire against the rim and then inflate it. It worked great. See pics.
This first one shows the tire not seated on the rim
01-05-2002, 02:41 PM #2Epic Contributor
- Join Date
- Aug 2001
- Posts
- 20,704
- Location
- Tractor
Re: Seating Small Tire On Rim
This one shows the ratcheting tie down strap around the tire and tightened.
01-05-2002, 02:44 PM #3Epic Contributor
- Join Date
- Aug 2001
- Posts
- 20,704
- Location
- Tractor
This last one shows the tire inflated and holding air. Thanks PTRich for the help!
01-06-2002, 09:55 AM #4
- Join Date
- Feb 2001
- Posts
- 470
- Location
- Lyndeborough, NH
- Tractor
- Kubota L5030HSTC, Farmall SuperC
My experience has been that the least little grain of sand results in slow leaks on small tubeless tires. I have a JD 325 that is basically "inflate before use" until I get tubes placed in all the tires. Like the rachet strap idea though.
01-06-2002, 10:01 AM #5Veteran Member
- Join Date
- Nov 2000
- Posts
- 1,720
- Location
- Columbia county NY
- Tractor
- 87 Ingersoll 444, 84 Ingersoll224/'44 GreavlyL/60'sGreavlyL/49 Ford 8N
I'm with Andy. Put a tube in it.
01-06-2002, 07:10 PM #6Silver Member
- Join Date
- Nov 2000
- Posts
- 126
- Location
- CA, Placer County
- Tractor
- 1999 Kubota L4310 HST 4WD, R4 Tires, Folding ROPS, Kubota Canopy
MossRoad,
Great idea. I have also used a rope with a long boad as a tourniquet to do the same thing. I have found that the rims do need to be pretty clean or nothing will work or they will leak. You can also buy a "bead expander" form the autoparts store witch is just a adjustable innertube in a nylon cover.
01-06-2002, 07:57 PM #7Gold Member
- Join Date
- Nov 2001
- Posts
- 322
- Location
- Northern Kentucky
- Tractor
- l245dt
well i have been told that if you take either and pour a little into the tire and then toss a match from a safe distance that it too will set the bead. but i never have tryed i use the rope trick.
01-06-2002, 08:17 PM #8Epic Contributor
- Join Date
- Aug 2001
- Posts
- 20,704
- Location
- Tractor
Ether + fire = no eybrows!
01-06-2002, 09:52 PM #9Super Star Member
- Join Date
- Aug 2001
- Posts
- 11,474
- Location
- Upper Midwest USA
- Tractor
- JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
That trick can cause the wheel (tire) to ricochet wildly off the walls and the ceiling of the shop too. Not a good practice. You may be mistaken for a wall, as this is an unguided system.
01-06-2002, 10:25 PM #10
- Join Date
- Jul 2001
- Posts
- 477
- Location
- Fort Kent, Maine
- Tractor
- B6100D Kubota
Picked up 3 persons who tried that trick in the last 5 or 6 years. None of them ever want to try it again, all will walk with a limp for the rest of their lives, and one almost had to have an artificial leg. Not worth it.
