Results 1 to 8 of 8
03-17-2007, 08:31 PM #1Platinum Member
- Join Date
- Jan 2005
- Posts
- 711
- Location
- Dunlap TN 25 miles north of Chattanooga
- Tractor
- Early 1949 Ford 8N
Disk Harrow Disk Size
I recently bought an old 5foot 3pt disk harrow.
The front and rear gangs are both notched disks.
The front disks are wore out bad. Notches are almost worn off.
The rear disks look to be in good shape. But what size are they.
I measured one today and this is what I got.
So what size disk is it? I need 8 disks for the front.
Still working on finding out what brand it is.
Can't read the tag very well.
Thanks.
Pooh Bear
03-17-2007, 09:34 PM #2Super Member
- Join Date
- Aug 2005
- Posts
- 7,514
- Location
- Mt Washington, Kentucky
- Tractor
- Where do I begin.....
Re: Disk Harrow Disk Size
You want 18" disc blades. TSC will (should) have them. What size axles? (They'll probably have 2 choices) Square or round? I just bought a few. Got 'em through Agri-Supply. They shipped 'em right to my door for less than I could buy locally.
This picture is getting a lot of press here lately.There are three kinds of men;
1.) The ones that learn by reading
2.) The few who learn by observation
3.) The rest of them have to pee on the electric fence for themselves.
03-17-2007, 10:01 PM #3Veteran Member
- Join Date
- May 2004
- Posts
- 1,067
- Location
- Murphysboro, IL
- Tractor
- Allis Chalmers D 14, Ford 3910
Farmwithjunk my neighbor has a MF disc just like that, and I've used it alot of time sbehind my dads 135 with the Z145 engine, prolly gives your 150 about the same workout in good soil. Do those front notched blades really help that much? His has full round blades and it does a wonderful job in our good ole Southern IL clay.
Speaking of your 150, wanna sell it yet?
03-17-2007, 10:39 PM #4Super Member
- Join Date
- Aug 2005
- Posts
- 7,514
- Location
- Tractor
The 150 is a Perkins diesel that's turned up a bit. (47pto) I used the disc in the 8'-10" trim. The 150 handled it well. I need to haul it from time to time and the 7'-6" width is "legal".
Originally Posted by Birdhunter1
Notched blades do a little better digging in sod or shreding stalks. No advantage in plowed ground.
The ol' 150 turns 36 in a couple months. I think I've grown accustom to it being here. Not ready to sell just yet. (I wrote a check for $3775 for the 150 in 1971. I believe I've got my money's worth)There are three kinds of men;
03-17-2007, 11:21 PM #5
get the disks the same size as the not worn backs...
L2500
03-18-2007, 06:10 AM #6Platinum Member
- Join Date
- Jan 2005
- Posts
- 711
- Location
- Tractor
The "not worn" back disks are what I measured.
I believe the center hole is square, not round like I drew.
It was just easier to draw a round hole.
The thing works pretty good as it is.
I bottom plowed the garden and I really tear up the dirt when I plow.
I ran thru it a few times with the harrow and chopped it up good.
Other than being kinda heavy for my 8N to pick up it pulls it really well.
Thanks.
Pooh Bear
03-18-2007, 06:21 AM #7Super Member
- Join Date
- Aug 2005
- Posts
- 7,514
- Location
- Tractor
You'll find there are several axle hole sizes. One is sort of a "star of David" (only with 8 points instead of 6) shape that fits 7/8" round or 1" square. Also, you'll find 1-1/4" square holes. (And some bigger sized holes too) They do need to fit the axle fairly close, even when tightened, the disc blade will move some. Too big of an axle hole allows them to "wallow" around, wearing into the axle.
03-19-2007, 11:52 PM #8Platinum Member
- Join Date
- Jan 2005
- Posts
- 711
- Location
- Tractor
Could y'all take a look at my post on the Attachments board
and see if you can shed some light on my question.
Pictures of my disk harrow are included there.
Thanks.
Pooh Bear
help-identify-disk-harrow-please
