A couple more video clips
   / A couple more video clips #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Wife is not much of a camera woman. Will try someone else at a later date.
One sequence is of how I have to brush hog. Not code, not that safe, but it works. Yes, the PT stays stable elevating the mower that high, and the mower leans back so the blades never face me...
One sequence of slope mowing. It was just a small hill around 30 degrees. But the tractor definitly slips. Need to ask Terry about what I am doing wrong.
Finally, the wife trying out the back hoe. Give an idea of how it works...
YouTube - Broadcast Yourself.
   / A couple more video clips #2
At 30 degrees I would expect some slippage. Two factors that can influence the amount of slippage are tire pressure and a properly adjusted draft control. Of course the draft control has to be turned on!
   / A couple more video clips #3
At the risk of sounding like the saftety police -- please consider doing us all a favor and add some thick plexiglass or some type defensive cage to the front of your ROPS if you're going to lift it that high! ;) We want to see more of these videos on a ongoing basis! :D
Seriously, I've lifted mine a couple of feet, but felt apprehensive doing that -- I certainly wouldn't want to lift it that high... things (sometimes bad things) just happen too quickly for me to react in time!
Nuff said on that subject -- I don't want to sound like a nag...
As previously mentioned, it may be a factor of draft control. Though my PT-425 doesn't have draft control (only float) I found a few occasions where lifting the cutter slightly would put enough weight on the front to stop the slipping/crabbing...
Couple of observations here...
First, the Lackender hoe looks MUCH heavier duty than the PT one, but it also looks longer and heavier. I wonder how much potential lifting capability you sacrifice to the longer boom and heavier weight...
Second, I've found that the bucket curl on the hoe is MUCH stronger than the down-pressure provided by the lift arms and the weight of the PT. Consequently, that's the force I dig with, most of the time -- curling the bucket on the end of the boom, not curling the PT's QA plate. If you can put the boom more straight out in front of you (instead of having the QA curled down), you might find that the increased length of the lever (bucket) from the fulcrum (PT) will allow the PT's weight to put more down-pressure on the digging point of the bucket, to resist the curling of the bucket. Curling the bucket with it extended as far out in front of the PT as possible will tend to lift the front of the PT less... at least that's the way it seems to work for me. Does that communicate and make sense?
Please keep the videos coming! It allows all of us to "live vicariously" though them... even if it does generate some "diesel envy" for those of us with green PTs... :eek: :D
Thanks for all the replies.
I run 12 to 15lbs on the inside and 8 on the outside. Will try to up the draft a bit to see if that helps. I am surprised it breaks at such a shallow slope so will check adjustments.
As for the safety police. Appreciated and understood. It is a risky maneuver, but on the 1850 when you lift the mower the front end goes up, back end is down out of eye line, and then a rubber flap lowers it further. I actually have not had any debris come my way using this method, but I did take a cheap shot in simple mowing when I bumped a stump and the decks nose dug in to the ground and I got to see the spinning blades of doom.
I have been mulling bolting my sides up so the deck will not sway, this would guarentee the deck not coming my way, but would also hamper any sort of float and give across normal ground. Have to think it through...
As for Lackender, yeah it is a 7 ft boom. A bit long for my PT. Clearly heavier, but you are only lifting a bucket of dirt. Now that said I realize I have plans to pull logs out of the stream and use this device. I doubt the weight difference is much more than 150lbs... And thanks for the technique, still learning all the implements (we have only 25 hours seat time and I am just trying to get comfortable with backing up ;-)
Carl
   / A couple more video clips #5
I run about 7.5 lbs for steep mowing work. The manual that came with my 1845 suggested pressures as low as 5-6 lbs. and I think for traction that is not a bad pressure.
However the OEM 2 ply tires would roll off the rim at such low pressures. I now run 6 ply tires and have tubes in them and run at 7.5 lbs and find it works pretty well.
I suspect using different pressures inside and outside may tend to decrease traction a bit--you may want to try using the same pressure all around--and on the lower side for steep mowing. Of course for bucket work and perhaps with the hoe higher pressures would be desirable.
Wow, that low of pressure. Great advice. I guess I no longer need a compressor and can inflate my tires orally....
   / A couple more video clips #7
Following Fourteen's advice on my PT-425, I run 11 PSI on the front and 9 PSI on the rear. The higher PSI in the front theoretically offsets a load in the bucket...
   / A couple more video clips #9
Carl
Carl, this is my solution. I replaced the two back stop bolts and nuts with a steel rod, drilled out on the ends for linchpins. If I line up the holes in the pivoting arms with the holes for the stop bolts, I can run the rod all the way through and lock the deck so I can curl the deck to almost vertical. when I want the deck to pivot front to back like normal, I just run the rod through the stop bolt holes as you should be able to see in the pic.
   / A couple more video clips #10
Just a word of caution... I've had the brush hog blade let lose two or three times. It doesn't stop for anything. It does not fly in a straight line. It travels in excess of 50 feet. Since implements change so fast on the PT, have you considered knocking down the big stuff with your bucket first, then mulching it with the brush hog at a lower angle? That's what I do in situations where things won't push over with the hog at ground level. It works really well. I highly recomment it. ;)
That hoe looks really handy. Have you considered an electric solenoid valve with a pushbutton on the joystick so that you can switch one of the joystick functions to the bucket curl while the button is pushed? A few folks have installed them and they look really handy.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2016 Ford F-550 Enclosed Service Truck (A55852)
2016 Ford F-550...
2005 Military Trailer (A53424)
2005 Military...
CATERPILLAR 259D SKID STEER (A52707)
CATERPILLAR 259D...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2006 Gehl RS5-34 6,000lb 4x4 Rough Terrain Telehandler (A55851)
2006 Gehl RS5-34...
