Red Zebra
Whatayaknow! I had a little time before we run to the airport and pick up one of my kids from summer camp.
The patient here is a 44" pull behind finish mower. I purchased for $200 bucks used about 8 mos ago to pull behind the riding mower. Works well and cuts as good as the JD.
I had an old receiver hitch from a '99 Malibu. I inverted it be the basis of a nose wheel. It fit perfectly. Also on the R side (facing the mower) the hith
tubing is open....I will use appropriate size tubing to reattach the pull arm either to the front of the mower or the side and continue to use it behind the JD when needed.
The idea of the hitch came to me while figuring out how to make a removeable nose wheel. Now I just remove the bolt and slide it out...reattach the pull arm and can get the JD going with it again.
Tomorrow or later this week I will fab the mount for the PT. The center of gravity is forward....in line with the engine. Will attach plates just behind the where the hitch is welded to the mower, then come up high enough to clear the motor.
More later.........
More later.........
