Wide-trac PT 1430
   / Wide-trac PT 1430 #1
DonStillwagon
Member
Murphy, NC
PT1430 (2002), PT1430 (2022)
This post is in response to a question by Carl (Woodlandfarms) - he was perceptive to pick up on a side comment I made on a previous post, and asked for pictures. I thought a new thread might be worthwhile.
While doing some major hydraulic repairs due to failure of a defective internal shaft in a wheel motor, I took the opportunity to add some stability to the machine by widening the stance to 58". Choose to do 58" due to 60 inch brush cutter and bucket. Pictures are attached - I just marked and cut the wheel motor boxes off about half way out with a sawzall and a demolition blade. Cut some 6" x 3/8" plates on a bandsaw, clamped everything tacked it, checked for square and welded it all back together. I kept moving around with the welding to avoid distortion. Using the plates as gussets simplifies the welding. Had to employ the stick machine to reach some areas, MIG on rest. Had to modify the plates on the rear of the front boxes for parking brake pin clearance - did a butt weld extension with a narrow gusset above the brake rod. I make my brake pins from standard rod - just drill and tap it appropriately, and in this case make it for the new length. I rerouted the hoses to the front motors and gained the length needed. Only one rear hose had to be replaced with a longer one. I also added some 1/4" x 12" plate to the front of the machine to protect things and to strengthen the area due to the increased moment arm from the wider stance. Note the Debris shield of belting material on th top of the new boxed area - helps keep mower and chipper debris out - not pretty but it works!
The machine is much more stable on slopes when mowing and there is a really big difference when lifting things with the forks or buckets on inclines. With the White wheel motors, this keeps the moment arm on the motor shafts within the original limits. Reversing the wheels is not an option with these motors, if you look at the design curves available on the White website.
Don
   / Wide-trac PT 1430 #2
Don
All I can say is WAY COOL.... I am allready as wide as I need for my machine but your design for the brush protector on the front is brilliant. I get so much junk stuck in there from working in my deep brush....
Great work. Got some pictures of it finished and in action?
   / Wide-trac PT 1430 #3
Dear Don,
Amazing job!
When you say it is more stable on slopes, how steep are you talking about? i.e. 15, 20, 25, 30, 35...? Donuts and coffee on fifty degree slopes? :)
If I do the math right, the 1445 is 58" wide, while the 1845 is 70" and the 1850 is a whopping 84", but your 1430 is a lot lighter that 1445.
Just curious,
Peter
   / Wide-trac PT 1430 #4
Don, thanks, for the pics. I have put this mod on my to do list. Now have to find the time to make the changes. My problem is the list keeps getting longer and not much get off the list.
Portable Restroom (A54865)
Portable Restroom...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A55851)
2025 Kivel 42in...
UNUSED WOLVERINE MAD-12-12D HYD AUGER DRIVE & BIT (A57193)
UNUSED WOLVERINE...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
FORD F550 SUPER DUTY SERVICE TRUCK (A57192)
FORD F550 SUPER...
