#1 (permalink) |
On my 1850 I have to take the side cover off the engine with two bolts to properly blow it out. I had the welder out so I cut the plate up, welded some hinges on it and but a washer on one of the bolts to act as a thumb screw and now I can easily access the oil radiator. This, along with the raised out take vent should help keep the PT running cool... Just tell me this. Who in the heck decided it was a good idea to put the engine air intake and cooling intake in the back of the tractor where all the dust can get sucked in... Dumb design..
Also, I am just learning to weld, and I found doing this that doing thick 1/2" steel is much more forgiving than this thin stuff....
__________________
Power-Trac 1850, grapple, hoe, 90" mower, 72" box blade Last edited by woodlandfarms; 07-20-2008 at 07:56 PM. |
#2 (permalink) | |
Super Star Member
Quote:
#3 (permalink) | |
Gold Member
Dear MR,
I'm going to stand up for the folks at Deutz here. The engines are used all over; if you are an OEM ordering engines, there are lots and lots of alternatives for the engines and cooling. I think the design improvements rest at PT, who are the final arbitrators of air source/quality, and oil cooler sizing. PT elects not to use the standard Deutz cooling cowl for some reason. The fact that a number of the PT users overheat them without additional efforts (cleaning the oil coolers/ additional fans/cooling coils) speaks for itself. Whether we're a vocal minority or speaking for the silen majority is beyond my ken. I think Altavista's success in using a larger oil cooler fan says quite abit about what might be readily achieved, as does Charlie & Sedgewood's filter designs. As always, YMMV. To address Carl's original point: moving the air intake up would clearly help. So would getting a consistent air flow scheme, e.g. right hot, left cool, and moving all the air in one direction. Generally speaking, a rear intake in a front mowing situation is generally a good location to miss directing large amounts of chaf into air intakes, but it doesn't reduce it to zero, as we all know. :-) I've pushed brush out a dirt road that had me and the tractor enveloped in a clouds of dust. I'd need to add a secondary engine oil cooler to keep up with all of the dust on the cooling fins, and increase the hydraulic fan cfm, if not add a secondary cooler if I were going to do this routinely. For the moment, I'm just blowing it out more often. On our old Deutz tractor, the cooling assumed you would have it coated with dust, and was sized accordingly. I don't ever remember cleaning it out, but the spacing on the cooling fins might have been 3/8". When haying season hit, it was going pretty much all day, every day, mowing, raking, baling and hauling hay down dirt roads. Dust, dust, dust. All the best, Peter Quote:
#4 (permalink) | |
Super Star Member
Quote:
#5 (permalink) | |
Gold Member
I agree with you.
The Aebi has this design for the hydraulic cooler. (They use a Kubota engine.) Given the Deutz design, it wouldn't be hard to do with an off engine oil cooler. All the best, Peter Quote:
#6 (permalink) |
I recall that someone did some investigation and determined that Deutz makes a radiator for agricultural applications. It has larger air passages. I think the problem is that PT has provided a radiator that is designed for clean applications.
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
