HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Brand Specific Forums > Power Trac
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 07-29-2008, 08:28 PM   #1 (permalink)
Default How hot is hot?
I have been experiencing the dreaded shutdown of my 25 hp Robin on a regular basis. I can mow for about 30 minutes and then the engine starts acting funny. I can keep it running by nursing the choke, but I think it is more than that?
Just for kicks, I put a temp gun on the cylinder heads, (not near the exhaust), and saw 270 degrees??
Thoughts?
__________________
Diggin' dirt in Lancaster County with my PT-425
pequeajim is offline   Reply With Quote
Old 07-30-2008, 01:38 PM   #2 (permalink)
Phils's Avatar
Default Re: How hot is hot?
Sorry I don't know the temps, and I have no excuse since I own an infrared thermometer.
You might want to add a fan... it stopped my vaporlock problems. I put mine on it's own toggle switch but will be changing that so it's on whenever the PT is running (although I'll probably leave the toggle switch but make so I can turn the fan off if a reason presents itself).
Phil
Phils is offline   Reply With Quote
Old 07-30-2008, 11:13 PM   #3 (permalink)
I had a similar problem and ended up replacing fuel line, and fuel filter. Then i cleaned out the junk stuck in the fitting at the bottom of the fuel tank along with other junk in the tank. Then made my way to the carb and cleaned junk out of bowl, seat and channel for needle valve and last but not least, removed fuel shut-off of valve and cleaned the crap out of there. Haven't had any problems after all that.
I think the main culprit was the junk in the fuel shut-off valve, but im sure if i hadn't cleaned the rest it, would have just ended up right back at the fuel valve.
cqaigy2 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
