Tree spade
   / Tree spade #21
This is what I am talking about.
   / Tree spade #22
J_J, how thick is that spade. I could build something like that pretty easily.
   / Tree spade #23
Bob, They really don't say. They only state heavy gage steel. It does weigh 41 lbs. I am guessing 1/4 in. but 3/8 in would be stronger. They have about 5 different versions.
Here is a link.
Quick Spade
   / Tree spade #24
J_J, thanks for the link. It looks like for many things (like trenching) this is similar to a back hoe or minihoe, but it would not have the leverage of the curling backhoe. For taking out a stump it would be able to work around the tree and cut the roots. As an add on to a bucket I would see some advantages. Do you have any thoughts on this.
   / Tree spade #25
Bob, It would be good for those operators that do not have a mini-hoe. It is light weight, easy to install, and can dig faster and deeper than a human.
   / Tree spade #26
Hi, Im trying to design a tree transplanter for my school project. But I am not sure how to calculate the force required to push the blades into the ground. Does anyone has any idea how to determine that?
   / Tree spade #27
You would have to put a force scale on the blade and measure how much weight it takes to break the soil. Also, a lot of it depends on blade shape, size, weight, soil type, moisture content, etc... lots of variables.
   / Tree spade #28
   / Tree spade #29
Moss, if you want to try the tree spade I made for my 425/refine ideas, contact me. I built mine from the frame rail of a semi tractor ( high carbon heat treated steel ?} similar to the picture JJ posted. Works fine up to 4'' hardwoods, after that the tap root is to much for lift capacity of tractor
   / Tree spade #30
Nope. I was just responding to the one poster. Seems he only posted one time. Thanks for the offer, though. :)
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
2005 Ford F-750 Truck, VIN # 3FRXF75R05V113199 (A53422)
2005 Ford F-750...
2014 TROXELL 130 BBL VACUUM TANK (A53843)
2014 TROXELL 130...
2005 International 4300 Telsta Telescopic Bucket Truck (A52377)
2005 International...
Ford Tractor (A50120)
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
