HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Brand Specific Forums > Power Trac
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 12-16-2008, 02:22 PM   #21 (permalink)
Elite Member
SnowRidge's Avatar
Default Re: fire wood splitter
I looked at those units at NH. I don't care much for the design. They had the Powerhorse splitters on display alongside this machine, which made them look like toys. As to their functions, there is no auto return valve, so you have to place logs from both ends of the machine, or run the wedge back manually. They only handle 19" logs, which may be all you need, but the majority of splitters seemed to be designed for something a little bigger.
You would hook the unit up to the PTO QDs. You probably would not have to run the PT at full throttle.
SnowRidge is offline   Reply With Quote
Old 12-17-2008, 09:26 PM   #22 (permalink)
Gold Member
SnowRidge,
Thanks for the input.
Would you have to do anything to the connections on the PT PTO QDs or on the Powerhouse splitter to make them go together?
ldabe is offline   Reply With Quote
Old 12-18-2008, 12:14 AM   #23 (permalink)
New Member
Quote:
Originally Posted by J_J View Post
Here are a few.
I saw one like these bolted on to the rear wheel of a truck about 60 years ago.
My dad and I had one of these - exactly like the "STICKLER" in the picture - and used it a lot. I still have it in the back of one of the barns - I don't (and wouldn't) use it today, but it's great to show people and see the look on their face when I tell them what it does. We were always a little impatient - the idea was to let the truck idle and let the screw work its way through the log. Dad had me sit in the truck and goose the throttle a little to make the thing split faster. Picked the truck up one day and almost set it off the jack stand when we hit an extra tough log. Ahhhh, those were the days...
__________________
Greenrancher
**2006 JD790, FEL
**1996 Grasshopper 54" ZTR
**197? International Lo-Boy, 60" belly mower
**194? Farmall H (ready for someone else to restore)
Greenrancher is offline   Reply With Quote
Old 12-18-2008, 01:07 PM   #24 (permalink)
Elite Member
SnowRidge's Avatar
Quote:
Originally Posted by ldabe View Post
SnowRidge,
You would have to fit matching QDs to 1/2 inch hydraulic hoses and connect those to the Powerhouse splitter. Any good hydraulic shop should be able to make them up for you.
Old 01-14-2009, 01:10 AM   #25 (permalink)
New Member
we are wanting to purchase areplacement screw auger of the same design on hibeams kioti log splitting attachment.
littleal is offline   Reply With Quote
Old 01-23-2009, 10:42 AM   #26 (permalink)
Just an idea for a cheap log splitter that might do for lighter splitting. It would have more power than the screw types that I have seen.
stray is offline   Reply With Quote
Old 01-23-2009, 11:06 AM   #27 (permalink)
J_J
Super Member
J_J's Avatar
Quote:
Using those figures. That makes that shaft size 1 in, and that is not a good thing. Bare minimums at best.
__________________
J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done, if-fen you want to..
J_J is offline   Reply With Quote
Old 01-23-2009, 12:09 PM   #28 (permalink)
Well there JJ. Explain that so these good people will know what you mean. It might be they can fugure it out but i can't.
Old 01-23-2009, 01:06 PM   #29 (permalink)
Super Star Member
MossRoad's Avatar
I think he's saying you need a larger cylinder as one with a 1" shaft is kind of tiny and could bend under that kind of load. And, if you increase the shaft size, your cycle time will slow down.
__________________
MossRoad
Click On My Little Tractor
To See Pictures And Videos
Of It In Action!!!
MossRoad is offline   Reply With Quote
Old 01-23-2009, 02:13 PM   #30 (permalink)
Now this is starting to get plum silly. Bigger shaft= stronger cylinder yes but, shorter cycle time. Cause less area to fill on the return stroke. I can fill this going on and on so I will just say that my post was much more for an example than it was a blue print. I should have written a disclaimer.
For example only, Author not responsible for calculations, design or materials represented.
Also I must confess, guess I was fishing for one of those legendary responses from JJ. He will keep you on your toes. Got to love him,
Last edited by stray; 01-23-2009 at 02:15 PM. Reason: font translation between programs was off
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.41267 seconds with 9 queries
