Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Gold Member
    Join Date
    Mar 2004
    Posts
    250
    South East Pa.
    PT425
    Default 425 Wheel Motors
    Has anybody resealed and installed bearings, if necessary, in their own wheel motors. I've down loaded the seal installation instructions, it doesn't seem to be a difficult repair. Any personal experience would be appreciated.
    SG
  2. #2
    Join Date
    Jul 2004
    Posts
    100
    Northwest Mass
    power-trac 1430
    Default Re: 425 Wheel Motors
    i've attempted to repair my 1430 wheel motor once so far. i took off the back end to replace the seals but when i was putting it back together some of the bearings that were on a ring fell out and these were not in the seal kit. so, in order not to cause any more damage to the motor i bit the bullet and sent it down to Power trac for the repair. next time, i have a have a better idea of what to order from a white distributor for the other bearings that i may need in addition to the seal kit so when i attempt it again next time i will have all the parts that i think i will need on hand so i can do it all in one shot. one tip: take some red fingernail polish after you take the motor out and draw a line down the center of the motor so you have a reference of how it all aligns when you put it back together. Hope this helps.
  3. #3
    Elite Member SnowRidge's Avatar
    Join Date
    Jul 2003
    Posts
    3,091
    East Tennessee
    Power Trac PT-425 / Branson 3520
    I had a leaking seal in one of my 425's wheel motors. It's been so long ago that I don't remember any details, other than I bought a seal kit for it. I do know I cleaned everything in a parts washer before I put it back together.
    I have a 20 ton press. I'm pretty sure I had to use it.
    I have another wheel motor that developed a leak on the self. I just haven't gotten around to fixing it.
  4. #4
    Gold Member
    Join Date
    Mar 2004
    Posts
    250
    South East Pa.
    PT425
    Thanks for the help. I guess it's not to popular repairing your own wheel motors. I'm going to try it after I get a spare motor. I've found several places to purchase the motor at a better price. Horticattleman states the shaft is ground to PT's spec. is this true.
    sg
  5. #5
    Silver Member horticattleman's Avatar
    Join Date
    Mar 2009
    Posts
    113
    South Central Louisiana
    CT335
    I dont exactly remember what was the deal with the motors (Powertrac sent me the first three replacements under warranty and I bought the last one from them like an idiot).
    I am sorry now I remember. It was the motor on the trencher that was milled down and White said they could not provide a replacement.
  6. #6
    Join Date
    Jan 2005
    Posts
    668
    SW Virginia
    PT425
    The wheel motors have a standard a 1-1/4" tapered shaft.
  7. #7
    Gold Member
    Join Date
    Mar 2004
    Posts
    250
    South East Pa.
    PT425
    Why did your wheel motors need replacing and not repairable.
    sg
  8. #8
    Elite Member KentT's Avatar
    Join Date
    Mar 2005
    Posts
    2,838
    Sevierville, TN
    1993 Power Trac 1430 w/Kubota diesel engine
    Quote Originally Posted by Gravy View Post
    The later model, "higer torque" White CE ones have 1.25" shaft. The earlier model, White RS ones have a 1" tapered shaft.
    Power Trac PT-1430 w/Kubota diesel engine & numerous attachments
    Allis-Chalmers B-210 w/several attachments
    Yamaha Rhino 450 UTV w/numerous mods
    More pictures & info about my garden tractors
  9. #9
    Join Date
    Jul 2003
    Posts
    3,091
    East Tennessee
    Quote Originally Posted by kjm3232 View Post
    I scratch a match mark along the side of the motor. Solvent can't remove it.
  10. #10
    Join Date
    Jan 2005
    Posts
    668
    SW Virginia
    PT425
    Quote Originally Posted by KentT View Post
    Yep. Gotta make sure which version you have. I've got the "high torque" White motors. I shudder to think about working on my slopes with the "low torque" version...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
