Go Back   TractorByNet.com > Brand Specific Forums > Power Trac
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-06-2009, 10:13 PM   #1 (permalink)
Default Homemade Quick Attach Plate
Gents,
I need to move a 2 cu-yd concrete mixer around and did a search on the Power Trac section to learn from past experience. I found several clamp ons for forks and buckets and a couple receivers welded on bare Quick attach plates.
I think I'll go with the quick & dirty ball on the bucket for my needs....
But got to thinking, has anyone made a quick attach plate for a special use? Another forum search turned up blank.
The attach plate for my PT2445 looks to be about 1/2" thick. I think one could be made of heavy flat bar & angle.
Has anyone given it a try and what was your experience??
Thanks for your thoughts,
tim
__________________
"It's only Me 'n I'm home from the Sea..."
jaquetarr is offline   Reply With Quote
Old 10-07-2009, 07:01 AM   #2 (permalink)
ksimolo's Avatar
Default Re: Homemade Quick Attach Plate
I had some made for my 1850 and they work ok. I would not hesitate to make my own now.
Ken
__________________
PT1850, mini hoe, grapple, knuckle boom, stump grinder, brush hog
http://www.usadiscountgenerators.com...T1850Home.html
ksimolo is offline   Reply With Quote
Old 10-07-2009, 08:40 AM   #3 (permalink)
Elite Member
BobRip's Avatar
I made a few. Here is one with a 2 inch receiver on it. I consider this a medium duty version, but I have had no issues with it. I did use angle iron. I have posted this here before.
I have more pictures if you need them.
I used a piece of rebar as the front lip to go over the PT quick attach front plate.
homemade-quick-attach-plate-quick-attach-plate-cheap-light  homemade-quick-attach-plate-quick-attach-plate-cheap-light  homemade-quick-attach-plate-quick-attach-plate-cheap-light  homemade-quick-attach-plate-quick-attach-plate-cheap-light  homemade-quick-attach-plate-quick-attach-plate-cheap-light
__________________
Bob Rip
Pessimism is easy. Optimism takes a lot of work.
BobRip is online now   Reply With Quote
Old 10-07-2009, 09:15 AM   #4 (permalink)
Thanks for your pictures. What you show is pretty much as I had envisioned.
Don't know why it did't show up in my 'quick plate' search.
Guess it's time to get out the welder,
tim
__________________
Old 10-09-2009, 08:18 PM   #5 (permalink)
Gents,
After reading Bob Rips post, I redid my search for "Quick Attach Plates" and spent most of the evening reviewing the excellent ideas there. I think the easiest and cheapest solution for me is to take one of my least used attachments with easily accessed bolts (trencher) and use the plate from it. I can fabricate a bolt on bracket from pre-owned 1/2" flat bar and angle, buy a receiver and weld it all up. When its bolted on using the same bolts, it should be strong enough to take any stress.
Since I'm new to this Forum, I'll try to post pics when its done.
I noted that several of the designs had hooks or eyes welded on the receiver. Have these proved useful? I could also weld a hook / eye on a mini boom for the same use.
B'Rgds,
Tim
__________________
Old 10-09-2009, 08:49 PM   #6 (permalink)
Elite Member
BobRip's Avatar
I use a two inch hitch receiver on a Q/A plate. (actually two, one on a home made plate and one on a PT plate. I then make attachments that will plug into that. This might work for some of your needs and it is quick to attach and detach.
I seem to use the two inch receiver every day. I have a boom pole, ditch blade, a "shovel" and other attachments that plug into it. I have posted it here.
Your other concept is also very good.
__________________
Bob Rip
Old 10-16-2009, 09:09 PM   #7 (permalink)
Well, I bought a new reciever & ball hitch, I had some 1/2"Flat bar and used that to fabricate the bolt on attachment.
Pklease see the pics attached (if I got it to work)
Flat black paint is the welders friend.
The four bolts come off easy and when I need to use the trencher, I'll swap the plate back.
Tim
homemade-quick-attach-plate-dscf0007.jpg  homemade-quick-attach-plate-dscf0009.jpg
__________________
Old 10-18-2009, 02:05 PM   #8 (permalink)
RegL's Avatar
Tim
Not to get off track but, How are the bolts attached to the plate. welded, threaded or is their a recess in the back of the plate for the head of the bolts? I can see where a bolt up qa plate would be handy for someone with out a welder.
RegL is offline   Reply With Quote
Old 10-19-2009, 07:28 AM   #9 (permalink)
Not off track at all,
The bolts are counter sunk flat head allen hex bolts that pass thru.
I took the plate off my trencher attachment. However I have a couple other attachments that bolt on as well, just not as easy to get to. From what I see, all the Quick Attach plates are drilled with a standard bolt hole pattern. These are new attachments (08-09), I can't say if older plates are so drilled.
Rgds,
tim
__________________
Old 10-19-2009, 10:54 AM   #10 (permalink)
woodlandfarms's Avatar
My mower has the same QA Plate. Never thought of repurposing it but that is a great idea...
I broke the bolt (flat head hex) on my mower. Initially I thought it was a PT custom but found them at the local store..
__________________
Power-Trac 1850, grapple, hoe, 90" mower, 72" box blade
woodlandfarms is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Page generated in 0.06684 seconds with 9 queries
