HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Brand Specific Forums > Power Trac
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-25-2009, 03:20 PM   #1 (permalink)
New Member
Default 422 New Head...
I put a new head on the 22HP Robin engine on my PT422 and have it almost complete except for the throttle and choke connections. I made some notes but want to make sure I got all the springs in the right holes. I'm having the PT towed to Ditch Witch and having the valves adjusted and the float position rebuilt on the lift valve. I would appreciate it if someone could post a picture of the connections. Not sure if it matters but the oil filling cap is black and on the side of the valve cover.
Thanks
Dan
SIDETRACK is offline   Reply With Quote
Old 10-25-2009, 08:51 PM   #2 (permalink)
Super Star Member
MossRoad's Avatar
Default Re: 422 New Head...
Welcome to TBN! Hopefully someone with the same engine will chime in.
__________________
MossRoad
Click On My Little Tractor
To See Pictures And Videos
Of It In Action!!!
MossRoad is offline   Reply With Quote
Old 10-25-2009, 08:59 PM   #3 (permalink)
New Member
Thanks for the welcome. PT has been down for a while and I sure miss it's many uses around the homestead. I have a 300lb+ anvil and base I'd need to move. Dan
Old 10-25-2009, 10:05 PM   #4 (permalink)
Elite Member
BobRip's Avatar
I sent them again and will send them here as well.
422-new-head-powerr-trac-throttle-choke-cable  422-new-head-powerr-trac-throttle-choke-cable  422-new-head-powerr-trac-throttle-choke-cable
__________________
Bob Rip
Pessimism is easy. Optimism takes a lot of work.
BobRip is offline   Reply With Quote
Old 10-25-2009, 11:58 PM   #5 (permalink)
New Member
Fantastic, just what I need to get everything put back the right way. Thanks for the help!
Old 10-26-2009, 10:33 PM   #6 (permalink)
woodlandfarms's Avatar
So, Sidetrack. What exactly did you do to your PT that would allow you to lift a 3K anvil? I want one
__________________
Power-Trac 1850, grapple, hoe, 90" mower, 72" box blade
woodlandfarms is offline   Reply With Quote
Old 10-26-2009, 11:21 PM   #7 (permalink)
New Member
It's a 300 lb anvil but still more then I can lift. What happened to it so it can't lift anything now is a bad valve guide.
Old 10-27-2009, 10:18 AM   #8 (permalink)
Oh man my eyes are going bad. I am sure I saw 3000lbs but now it is clearly 300lb. Still. Big ole anvil...
I have a dream of one day replacing the control valves with something of quality.... Something that doesn't leak down, that is too over sensitive, and that has more than one control. But that is just a dream...
__________________
Old 10-30-2009, 08:18 PM   #9 (permalink)
New Member
The PT was hauled out today to get the final mechanical touches. I installed a new battery that I got from the Kubota dealer since I couldn't match the old Interstate battery that I replaced. I got the Robin muffler from Northern Tool for just under a $100. I had to cut a small part off the muffler so that the motor cover could close. Looks like the old muffler was trimmed on both sides.
Hoping that when I get it back it comes off the truck a lot faster then it went on it.
Old 10-31-2009, 02:04 PM   #10 (permalink)
Gold Member
Could you post a few picts of the finished product?
Thanks.
cqaigy2 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.19086 seconds with 9 queries
