Results 1 to 9 of 9
  1. #1
    Join Date
    Feb 2008
    Posts
    130
    Default Exhaust overhaul
    I have not posted in some time but I read this board almost daily. I get great info and ideas for all of you. Thanks!
    It's cold as heck down here in South Louisiana, some folks think **** is freezing over cause the Saints may finally go to the Super Bowl, so I am pulling my winter maintenance. I'm doing mostly routine stuff but one thing I am doing is overhauling the exhaust on my 422. I got really tired of the excess heat generated by the standard PT exhaust system and the noise so I'm trying a little custom stuff.
    What I landed on is a piece of 1 5/8" exhaust pipe, two 1" nipples, and two generic 1" screw on mufflers, the big round ones. What I am doing is cutting the PT square tubing just past the second cylinder and will sedge up the 1" to the 1 5/8". That runs out the same notch that is cut in the cover. Once outside the cover I built a manifold with the two nipples welded into it and the mufflers will attach there. I figure I am at least doubling the exhaust path by doing this. I also picked up some exhaust wrap and plan to wrap the whole exhaust manifold out to the mufflers.
    I should have pictures in a day or two and will post them. I'm hoping for a much cooler and quieter 422. Wish me luck!
  2. #2
    Join Date
    Feb 2008
    Posts
    130
    Default Re: Exhaust overhaul
    OK, I did a bit more today. Here is what I have so far. With a bit more welding I'll be ready to try her out. So what do you think?
    Attached Thumbnails Attached Thumbnails Exhaust overhaul-img00062-jpg   Exhaust overhaul-img00063-jpg   Exhaust overhaul-img00064-jpg
  3. #3
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    Looks good.
    That's alot of weight out on the end of that, you thought about some type of support ?
    ::Sent from a standard desktop keyboard::
    My Photobucket
  4. #4
    Platinum Member tmarks11's Avatar
    Join Date
    May 2005
    Posts
    922
    Seattle, WA
    Power Trac 422 (2005)
    It probably weighs quite a bit less then the OEM PT 1/4" steel box muffler he took off.
    Tim
    2005 PT-422
    4n1, LMB, minihoe, 48" mower, brush hog, Land Pride aerator, Herd spreader, auger, towing, forks, box blade, plow, box blade, tiller, trencher
    PT422 (6/23/05) photo page
  5. #5
    Member
    Join Date
    Mar 2008
    Posts
    42
    Lakes Region, New Hampshire
    PT 425
    How did you make out, is it quieter than the OEM muffler? I would love to find something quieter.
  6. #6
    Veteran Member westcliffe01's Avatar
    Join Date
    May 2009
    Posts
    1,226
    SE MI
    Bobcat B200 TLB
    You need some volume, preferably something with some fiberglass inside to take the edge off. Take a drive to the exhaust shop and try a 3 way muffler, and if possible add an outlet pipe 2 feet long. If the muffler can be connected to the engine with flex hose, this allows the muffler to be hard mounted on the frame, perhaps with a vertical stack.
    Alternatively, look at places like smallenginewarehouse.com for mufflers off the Honda and Robin engines. They have better mufflers out the box.
  7. #7
    Join Date
    Feb 2008
    Posts
    130
    Well I finally finished this up over the weekend and tried it out. It is a bit quieter but not as much as I had hoped. The tone is much better and I must say the engine runs better. It is easier to start, seems to run cooler and has no backfires! I'd say it was worth it.
  8. #8
    Join Date
    Mar 2007
    Posts
    1,550
    Bay Area, CA
    Power Trac PT1445
    Dear SwampmanLA,
    Many congratulations! It sounds really successful. Are you going to post photos?
    An engine that starts easier, runs cooler and doesn't have backfires sounds like a great reason to have done it.
    On a separate thread, I saw a home video of someone that had welded a cheap $20 automotive muffler on some flex hose to connect it to his generator with a slip fitting. It knocked 30-40dBa off the generator noise. I have a similar model that is loud at the 60' distance.
    All the best,
    Peter
    Quote Originally Posted by SwampmanLA View Post
  9. #9
    Join Date
    May 2009
    Posts
    157
    Kerrville TX
    PoiwerTrac 2445
    I had to build a muffler for a 6 wheel swamp buggy I had one time. We used pipe stuffed with metal shavings. I believe they were SUS. The over size & shavings dropped the pressure & the shavings cooled th gas flow a little. Worked pretty good. The engine was quieter than the drive chains. The shavings might last longer than fiberglass.
    Rgds,
    tim
    "It's only Me 'n I'm home from the Sea..."
Similar Threads
  1. 3320 Vertical Exhaust Install (pics)
    By WH401 in forum John Deere Owning/Operating
    Last Post: 09-22-2011, 05:55 PM
  2. Damage from holes in muffler???
    By Mundy in forum Parts/Repairs
    Last Post: 04-20-2008, 09:41 PM
  3. D40 Exhaust Redirection
    By AKtinman in forum Customization
    Last Post: 01-07-2007, 09:10 PM
  4. Massey Ferguson GC2310 exhaust deflector
    By bassnfrank in forum Massey Ferguson Owning/Operating
    Last Post: 08-23-2005, 08:47 PM
  5. Horizontal or vertical exhaust opinions
    By Shadow_River in forum John Deere Buying/Pricing
    Last Post: 06-22-2004, 07:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
