Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    Gold Member 3238dpw's Avatar
    Join Date
    Nov 2006
    Posts
    349
    Central NJ
    Power Trac 425, C-121 Wheel Horse, 2 Exmark 60 inch zero turn mowers
    Default Water Tank
    In New Jersey we are currently in a drought. I was wondered if anyone has set up a tank on their PT to use for watering plants and their garden. Also thinking about a pump. Maybe collecting rain water. In the idea stages and there is no better place then this for ideas.
    Scott
  2. #2
    Elite Member sandman2234's Avatar
    Join Date
    Dec 2005
    Posts
    4,450
    Jacksonville, Florida
    JD2555 and a few Allis Chalmers and now one Kubota
    Default Re: Water Tank
    I would think water would be too heavy for a 3pt but a single axle would make it an easy chore.
    David from jax
    OPPS, PT... not 3pt....sorry
    A serious accident is one that money won't fix.
  3. #3
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Quote Originally Posted by 3238dpw View Post
    You should be able to fill and lift a 55 gal barrel with water, and tote it anywhere. Either gravity fed, or a small pump for spraying.
    55 gal full of water weighs about 440 lbs
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  4. #4
    Elite Member BobRip's Avatar
    Join Date
    Sep 2004
    Posts
    4,479
    Powhatan Va.
    2000 Power Trac 422
    I have a tank with Pump from Northern. I use it to put down nematodes. It holds 26 gallons.
    Attached Thumbnails Attached Thumbnails Water Tank-sprayer-001-jpg   Water Tank-sprayer-004-jpg
    Bob Rip
    Tell me and I will hear.
    Show me and I will see.
    Let me do and I will learn.
    Let me fail and I will understand.
  5. #5
    Silver Member frischtr's Avatar
    Join Date
    Feb 2010
    Posts
    151
    Harford County, MD
    PT-425
    I collect rainwater from the downspouts with 55 gallon drums. Mine are not mobile, as I have the overflows tied into the lower sections on the pre-existing downspouts. I suppose I could have set them up differently, but I have no need to move that much water at a time.
    By the way, collecting rainwater can be extremely efficient instead of running the well... With as little as 1/2" of rain I can collect 165 gallons of water with my 3 barrel setup.
    2010 PT-425 - 60" finish mower, 60" blade, 45" grapple bucket, 10cu' lmb
    2004 Dodge Ram 2500 SLT 4x4 5.9L Cummins HPCR Turbo Diesel QCLB NV5600 6-speed manual 4.10s
    IBEW Local #24
  6. #6
    Gold Member
    Join Date
    Aug 2010
    Posts
    330
    On the Oregon coast
    JD 870
    Default
    I know it sounds odd but check your state laws if you're visible from the road before you put in a rain water collection system. It's illegal in several states to collect rainwater. Apparently it's a public domain issue and is considered stealing the water from your neighbors and community.
  7. #7
    Join Date
    Jan 2009
    Posts
    1,319
    upstate South Carolina, Greenville
    Kubota M6800, Massey Ferguson 240
    I have a cistern, a 250gal. tank from TSC. I mounted it on a 40"high platform and collect from one side only of my shed. it stays full most all the time. It has a 1" outlet, so even gravity fed it can put out good flow. I use it for equipment washing, as it is my only water source, using a gas pump, of course. If I wanted to be mobile, I would still collect it this way and probably buy a smaller tank (about 100 gal) and pump from one to the other in a truck bed. THis way you could not have to disturb the "plumbing" I have a commercially available self cleaning screen mounted on the downspout to flush out leaves and debris. You can find these on many rain collecting websites. They are pretty cheap. I also would consider one of the 200 gal "totes" that I see for sale often, the ones with the metal cage. They sell around here for $50. Collecting water is really easy, if you have a roof. Gutters are cheap also.
  8. #8
    Join Date
    Jan 2009
    Posts
    1,319
    Quote Originally Posted by Redgoatea View Post
    Only on the West (left) coast!!!!!! Sad. Someday they will try to restrict the air we breathe (or tax it)
  9. #9
    Gold Member
    Join Date
    Aug 2010
    Posts
    330
    On the Oregon coast
    JD 870
    Default
    Quote Originally Posted by HCJtractor
    Didn't know it was only out here but that explains why I ran into it when I lived in Utah. Glad I left there.
  10. #10
    Join Date
    Nov 2006
    Posts
    349
    Central NJ
    Thanks for the ideas so far and welcome any more.
    I am thinking of something along the lines of a seperate tank for rain collection and a seperate one for moving it around the yard. I want to mount it either on a pallet or on a trailer. I could then tow it or if it was on a pallet I could use the forks. I like this thread I found but would like more thoughts.http://www.tractorbynet.com/forums/b...n-project.html
    Here are some pumps I found. Which one would be best/ Cabela's -- Rule Submersible Bilge Pump
    I would like to set it up like the guy in the first link did so the pump could be used to pump in or out of the tank. I can't figure out a way to make this pump work that way, so any thoughts would be appreciated. of course I like this pump because I am cheap.
    Scott
Similar Threads
  1. Press. Tank, Press. Switch Question
    By jimainiac in forum Rural Living
    Last Post: 02-11-2007, 07:38 AM
  2. Water Pressure Tank question
    By Shimon in forum Rural Living
    Last Post: 08-29-2006, 05:39 PM
  3. How to properly disinfect your water well......
    By Junkman in forum Rural Living
    Last Post: 07-29-2005, 01:45 AM
  4. Boiler and domestic hot water tank
    By PhilNH5 in forum Related Topics
    Last Post: 08-28-2003, 11:38 PM
  5. Water Decision
    By Alan L. in forum Rural Living
    Last Post: 06-28-2000, 05:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
