Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Veteran Member SpringHollow's Avatar
    Join Date
    Dec 2006
    Posts
    2,310
    South of Rochester, NY
    Power Trac 1850, NH 2120
    Default Protected Valve Stems
    I have been planning on welding pipe or metal to keep my valve stems from ripping out. I have never had this problem but it has happened frequentoy to others. Before i put my expensive sealer in, i figured i had better do something.
    Searching for metal valve stems, i found these recessed valve stems which might be a neat solution so I ordered them:
    Amazon.com: Flush Mount Chrome Valve Stem System (Set of 4): Automotive
    They are meant for fancy rims but might be a neat solution to the problem. I want to sandblast my rims but once i do, i will give them a try. Inflating the inner duals would be a pain but with the sealer, that should be a rare occurrence.
    Attached Thumbnails Attached Thumbnails Protected Valve Stems-51lcdt-f3-2bl-_ss400_-jpg
    PT1850, mini hoe, grapple, stump grinder, brush hog
    http://www.usadiscountgenerators.com...T1850Home.html
  2. #2
    Super Member dcyrilc's Avatar
    Join Date
    Nov 2009
    Posts
    5,490
    Woodinville, Washington
    John Deere 2240 MFWD
    Default Re: Protected Valve Stems
    Quote Originally Posted by SpringHollow View Post
    Just a word of caution if you decide to weld colars on the rims instead...
    Welding on any rim with a tire mounted (even deflated with the bead broken) can have explosive results. Always completely dismount the tire first.
    YouTube - Tire Explosion
    http://www2.worksafebc.com/PDFs/inve...5108320019.pdf
    http://www.forestryforum.com/board/i...ic=42557.0;all
    Cyril
    JD 2240 MFWD (with duels now)
    145 FEL, 8ft Rear blade (now I need a 12ft blade)
  3. #3
    Join Date
    Nov 2009
    Posts
    5,490
    The last one I posted was actually the video I was looking for and has much more information than the earlier ones.
    Thanks
    Cyril
  4. #4
    Join Date
    Dec 2006
    Posts
    2,310
    Thanks for the warning! I am aware of the problem of welding on a rim with a tire attached. I have seen it mentioned here but I must admit it would have never occurred to me to even try doing it.
    Ken
  5. #5
    Join Date
    Nov 2009
    Posts
    5,490
    Ken
    Good deal. I looking forward to hearing how those new stems work out.
    Cyril
  6. #6
    Elite Member jonyyuma's Avatar
    Join Date
    Sep 2010
    Posts
    2,972
    35 miles North of Memphis,TN
    kubota L3000dt, ford 8n1952
    It looks like they have made them even shorter now.I have used steel stems on my truck for many years. I only had one failure, due to jerk at tire repair shop. They never rot or Blow-out of wheel. I might just order some for my Bota. Thx. Jy.
    Okay, Legal disclaimer: Old but not senile, definitely do not have the answer to everything!
  7. #7
    Join Date
    Dec 2006
    Posts
    2,310
    Hi JY,
    These are not normal metal valve stems but recessed metal valve stems
    I just test fit one on a beat up spare rim I have and it looks like they will work. I can not say they will not leak yet but there was enough clearance that the cap nor the nuts hit the rim.
    After I actually ry them, I wll let you know how they do.
    Ken
  8. #8
    Join Date
    Dec 2006
    Posts
    2,310
    Now the big question is, can i remove the valve stems from these in order to add the tire sealer.
    Ken
    just checked to see - the internal valves in the stems look like they can be removed just like normal stems
    Last edited by SpringHollow; 01-08-2011 at 01:04 PM. Reason: checked to see - the internal valves stems look like they can be removed
  9. #9
    Platinum Member RegL's Avatar
    Join Date
    Aug 2003
    Posts
    652
    Northwestern CT
    PT 1430
    Do you need a special air chuck to put air in the tire?
  10. #10
    Join Date
    Dec 2006
    Posts
    2,310
    No, but you need to thread on an extension tube before you can add air. The extension has a piece of metal in it that presses down on the internal stem when you press down on the extensions internal stem with your air chuck.
    I really am hoping that this works out because it is a nicer solution versus welding on pipe or plate protectors. Pure luck that i happened to see them and realized that they might work.
    Ken
Similar Threads
  1. Loader Kubota FEL with 3rd Function Valve
    By rjkobbeman in forum Kubota Owning/Operating
    Last Post: 01-26-2012, 12:14 AM
  2. Replies: 13
    Last Post: 06-27-2010, 06:03 AM
  3. What does power-beyond really mean?
    By quicksandfarmer in forum Hydraulics
    Last Post: 01-05-2010, 02:39 PM
  4. Kubota Backhoe powered from rear remotes of TYM
    By myyaz33 in forum Hydraulics
    Last Post: 09-09-2008, 07:41 PM
  5. CAUTION Jinma 284 Hydraulic failure
    By RonMar in forum Chinese Tractors
    Last Post: 08-04-2005, 12:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
