OP
bubenberg
- Joined
- Mar 21, 2002
- Messages
- 945
- Location
- Bucks County, PA
- Tractor
- PT425, Kubota L2050, 3 hydrostatic Exmark mowers. Z21D Kubota ZTR, 2 Kunz acrease wing mowers, 1 rough cut kunz mower, one vintage grasshopper ztr, one vintage gravely ztr, various large garden tracto
<font color=green>what is your suggestion: wheels or no wheels to add to Cheap Plow?
No wheels; not yet - first I'd try some of those round, free to rotate, snowplow pucks and send a report. Thats what I want to try next, but a report from your test bed might save me some trouble {{grin}}</font color=green>
my homemade rubber lip (flat running surface of a poly truck tire) is not absolutely straight but notwithstanding the imperfection of my cutting job, the moving around of cinder on a long and slanted driveway (400feet) was the closest i could test the CHEAP SNOW PLOW (CSP) today,
Sedgwood you are absolutely correct ... NO WHEELS ARE NECESSARY .... in my opinion. the handcontrol, as it progresses with every hr of practicing full operation of the joystick. will do a much better job, rather than relying on the wheels.
the 2x20 inch piston with a 12 inch stroke was absolutely perfect for this application. response time to both side is equal to adjust the plowing angle. my suggestion is not to exceed the 2 inch diameter for the piston.
so my tally is $140.00 for the piston $40.00 for the labor 40.00 for the two hydraulic hoses compared to the pt $450.00 for the blade and $200.00 for the rubber lip. plus shipping.
