Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. #1
    Join Date
    Jul 2004
    Posts
    99
    Northwest Mass
    power-trac 1430
    Default changing brush cutter out for 6 blade grass cutter
    has anyone purchased the 6 blade grass cutter disc and attached it to the brush cutter frame? i purchased one last fall and started to take the brush mower apart to attach it and cant figure out how to get the big round bowl of the old brush cutter off and how to attach the disk. any suggestions would be helpful. thanks
    Attached Thumbnails Attached Thumbnails changing  brush cutter out for 6 blade grass cutter-100_0507-jpg   changing  brush cutter out for 6 blade grass cutter-100_0509-jpg   changing  brush cutter out for 6 blade grass cutter-100_0511-jpg   changing  brush cutter out for 6 blade grass cutter-100_0512-jpg
  2. #2
    Epic Contributor MossRoad's Avatar
    Join Date
    Aug 2001
    Posts
    33,718
    South Bend, Indiana (near)
    Power Trac PT425 2001 Model Year
    Default Re: changing brush cutter out for 6 blade grass cutter
    Holy cow that looks like a big old wheel of destruction!!!
    No clue how to get that hub off of the shaft.
    MossRoad
    Click On My Little Tractor
    To See Pictures And Videos
    Of It In Action!!!
  3. #3
    Gold Member Clumber's Avatar
    Join Date
    Sep 2010
    Posts
    358
    Northern Virginia
    PT425 (Dec 2010)
    Looks like an allen screw on the side in last photo. Remove that scew then you might try a gear puller to remove clamping part and the round blade disk. The next step will be determined by what is underneath. Good luck!
    Torin Jacks Integral Hydraulic Gear Puller — 5-Ton, Model# TRK0501 | Ball Joint, Bearing + Gear Repair | Northern Tool + Equipment
    I married me a hippy, ran away with a stringy haired blond,
    Now we're both old and happy, fishing on our own Golden Pond. -- Merle Haggard
    PT 425 (Dec 2010), Blade, Snow Blower, Sweeper, Spreader, LMB, 4n1, Small Bucket/Teeth, Utility Grapple, Brush Cutter, Box Blade, Mini Hoe/Thumb, Forks, Power Dumper
  4. #4
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    I think I would call Terry at PT. I believe it uses a different shaft, and gets rid of the drum
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  5. #5
    Silver Member Red Zebra's Avatar
    Join Date
    Apr 2007
    Posts
    166
    Fox Meadow TN
    '07 PT 425
    The 6 blade disk attatches to the "stump jumper" drum. there are 4 bolts holding the drum on...two of the bolts act as pivot points for the brush blades.
    Per the instructions from PT that came with mine: Remove all four bolts and attach disk using the 4 new bolts (they're all the same length). Although you can't see it in this picture...the drum is there.
    Attached Thumbnails Attached Thumbnails changing  brush cutter out for 6 blade grass cutter-6-blade-jpg
  6. #6
    Bronze Member rabidracin's Avatar
    Join Date
    May 2011
    Posts
    54
    upsate ny
    2011 Mahindra 3016HST, 1991 Bolens GT2000
    Just an observation but wonder why blades have two bolts and not just one shoulder bolt so that blade can spin if need be. Pretty much same concept as discbine. And that is how they are designed.
  7. #7
    Join Date
    Feb 2009
    Posts
    230
    south western michigan
    pt 425, JI Case, Gravely Comm.10A
    the disk attaches to the stump jumper, do yourself a favor and put on blades that utilizes one shoulder bolt and pivot freely ie; saves you the hassle of searching for blades after the two bolts holding the blade break off , I originally put a grade 8 bolt in one hole and a grade 2 in the other as a shear bolt, but it is still a time consuming process and I still lost blades, now I use short swinging blades I bought at the local farm supply store, 100+ hours with no problems
  8. #8
    Join Date
    Feb 2009
    Posts
    230
    looks like the wrong bolt pattern on the disk, mine only has 4 bolt holes and bolts to where the original bush hog blades bolted to
  9. #9
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    kjm3232,
    Can you tell us what that 6 bld kit cost?
    Is the shaft welded to the drum assembly?
    J.J.
    Git er done.
  10. #10
    Join Date
    Jul 2004
    Posts
    99
    Northwest Mass
    power-trac 1430
    Quote Originally Posted by washita View Post
    i didn't get any directions with this on how to mount it, other than the blades were bolted inwards for shipping. when i started to put this together i thought that it would have made sense to bolt it directly to the bottom where the brush cutter blades were attached to. but as you can see in my 1st photo, the bolt holes align at the top which hold the shaft to the brush cutter deck and not to where the blades are at the bottom. i figured that PT has some other design in mind because what they put together doesn't always make sense to us. Now that i saw red zebra's picture of how it's supposed to be i see that PT messed up with the bolt hole alignment.
    jj i think i paid $350 for it.
    thanks everyone for the responses and the pic on how it is supposed to be.
Similar Threads
  1. Stuck bolt on brush cutter blade
    By Homebrew in forum Power Trac
    Last Post: 05-25-2010, 10:18 AM
  2. Walk behind brush cutter.
    By _RaT_ in forum Rural Living
    Last Post: 05-10-2010, 08:49 PM
  3. Brush Cutter Blade Experiences???
    By marks in forum General Lawn & Garden
    Last Post: 10-30-2007, 08:26 PM
  4. Rotary Cutter Bought a Brush Cutter
    By ovrszd in forum Attachments
    Last Post: 05-02-2007, 04:41 PM
  5. 709 brush cutter
    By Vernon in forum John Deere Owning/Operating
    Last Post: 07-03-2000, 11:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
