Results 21 to 30 of 40
08-12-2011, 12:07 PM #21Gold Member
- Join Date
- Mar 2003
- Posts
- 460
- Location
- Beaverton, Oregon
- Tractor
- JD318, Power-Trac PT425 with scuffed-up green paint.
Re: Power Trac Future
I would LOVE a utility grapple. PT charges $800 plus shipping for these. Gotta save up!
I would also love a 'grubbing bucket', which PT doesn't product, but is basically a really small bucket, mounted just like the regular light material or rock bucket, that is used for digging up stuff - it is a replacement for a hand shovel.
Sincerely,
Rob
2003 PT425 with 25 HP Kohler Command Pro engine. Light material bucket, rock bucket, pallet forks, mini hoe, power sweeper, fine cut 48" mower, 48" brush cutter, custom 12v powered 25 gallon liquid sprayer (see avatar). Tow behind brinley hardy spreader, thatching rake, and plug aerator. Running Mobil 10W/40 dino oil for hydro (same as factory fill), Mobil 1 10W/30 for engine. Best accessory: spinning knob on steering wheel.
08-12-2011 12:07 PM # ADS
08-12-2011, 12:26 PM #22New Member
- Join Date
- Jul 2011
- Posts
- 15
- Location
- Maple Valley, Washington
- Tractor
- in limbo right now
Thanks Rob! If I'm down in Beaverton soon, I will call you in advance. Larry
08-12-2011, 12:58 PM #23Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,656
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
Look at this. You might even be able to build one.
http://www.northerntool.com/shop/too...6534_200356534
http://dai.ly/oUxMcP
http://www.youtube.com/v/Cbcezo8R8mE...dded&version=3
This one is $129
https://www.foryourshore.com/index.c...ry&Category=33Last edited by J_J; 08-12-2011 at 01:23 PM.
J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done.
08-13-2011, 02:48 AM #24Gold Member
- Join Date
- Mar 2003
- Posts
- 460
- Location
- Beaverton, Oregon
- Tractor
01-10-2012, 11:17 AM #25Member
- Join Date
- Jul 2010
- Posts
- 36
- Tractor
- none yet
for sale in WI
extreme brush mower
I'd consider getting it, but the lift is a bit anemic for the size of machine.
anyone know if you can just put the loader tires on it and beef up the lift arms and hydraulics or is it an entirely different chassis etc?
karl
01-10-2012, 06:51 PM #26Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,656
- Location
- JACKSONVILLE, FL
- Tractor
Sure you could beef it up , but can the wheel motor shaft take the extra weight.
The lifting force has a safety factor built in so if you lift the rated load, the rear end will not come off the ground. You could load the rear end down and lift more, but you do it at your own risk. The hyd can do the job, and you could up the relief pressure, but you will have to know all the specifics to do all this.J.J.
Git er done.
01-10-2012, 07:22 PM #27
Ok I like that idea. Back hoe costs to much for me right now and I really don't need something that extravagant but I wonder how hard it would be to fabricate/make one fit a PT 425. A strong quick attach plate and a way for it to mount to it. Probably a smaller digger version so as not to overwork the tractor. Hmmm ideas anyone or has anyone made one yet for the PT 425? Don't be afraid to chime in.
01-10-2012, 08:18 PM #28Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,656
- Location
- JACKSONVILLE, FL
- Tractor
You could make a smaller one of these.
J.J.
Git er done.
01-11-2012, 06:43 AM #29
Or you could take a minihoe and figure out some way to flip the bucket around. Wouldn't that essentially be the same thng?
Now in Vienna, VA
2005 PT-422
4n1 bucket, minihoe, auger, 48" mower, land pride aerator, tow adaptor, forklift, crane, Herd GT77 spreader, LMB, 60" blade, M1 abrams turret.
PT422 (6/23/05) photo page
01-11-2012, 08:01 AM #30Veteran Member
- Join Date
- Dec 2006
- Posts
- 1,535
- Location
- South of Rochester, NY
- Tractor
- Power Trac 1850, NH 2120
Some nasty leverage would be trying to tweak your loader arms. I am not sure I would want to try that.
KenPT1850, mini hoe, grapple, knuckle boom, stump grinder, brush hog
http://www.usadiscountgenerators.com...T1850Home.html
Similar Threads
Ventrac 4200VXD diesel vs Power Trac diesel
By NOSPARKPLUGS in forum VentracReplies: 4Last Post: 09-01-2008, 09:47 AM -
Bobcat Toolcat 5600 or Power Trac 1850 for 168 ac?
By BrianSouthernMD in forum Buying/Pricing/ComparisonsReplies: 66Last Post: 09-18-2005, 07:47 PM -
Power Trac PT-1430 For Sale
By KevinFleming in forum Power TracReplies: 1Last Post: 05-03-2004, 10:16 PM -
Power Trac PT425
By MossRoad in forum Power TracReplies: 493Last Post: 04-22-2002, 04:09 PM
