johara1
10 hr\'s on 422
well it was time to put the 422 to work,i ordered two tri axle loads of 2a mod. that came at the same time,late afternoon,so it realy had a workout.
i wanted to try the mod. on the blade,it was about 50%. i need to make the feet larger.you can still grade with it,iput a nice crown on with it, the tilt works great for this.
now the bucket worked great , it needs a little work to make it a little stiffer but over all very impressive.
the hyd. power is the best part,i don't know how any body could ask for more,the engine power is more than i expected!
the negative side,the engine just shut down for no reason. this happened twice. engine oil leak,one pint in 4 hr's, (valve cover gasket) hyd. leak(4 cyls. leaking around the rods) 1 female quick coupler on the pto leaking. total hyd. loss in 10 hr's 1 gal.
as you can tell a call to terry monday morning is in order.
i get these little bugs out i'll be a happy camper! /forums/images/graemlins/laugh.gif
