Page 1 of 5 1234 ... LastLast
Results 1 to 10 of 47
  1. #1
    Elite Member woodlandfarms's Avatar
    Join Date
    Jul 2006
    Posts
    3,439
    Los Angeles / SW Washington
    PowerTrac 1850
    Default Landscape plane questions
    I have a heavy duty 72" woods box blade. Works good but I reall feel a landplane will be way better for maintaining my roads. So here are mybuestions and happy to take all comments? I am going to build this implement.
    Anyone have one?
    Push or pull? I am so tired of pulling butt think the pt arms are going to be an issue and oushupingbwill never work. But my runners should be quite long 5 ft at least.
    I can pull the box blade unless I am on a slope and the box blade really loads up. I am thinking about an 84 inch wide landplane.
    Power-Trac 1850, grapple, hoe, 90" mower, 72" box blade
  2. #2
    J_J
    J_J is offline
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    13,492
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: Landscape plane questions
    Here is one built by a TBN member.
    http://www.tractorbynet.com/forums/b...completed.html
    Some other pictures.
    Attached Thumbnails Attached Thumbnails Landscape plane questions-landplane.jpg   Landscape plane questions-landplane-001.jpg   Landscape plane questions-landplane-x749-001.jpg   Landscape plane questions-landplane-004.jpg   Landscape plane questions-landplane-1-.jpg
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    Epic Contributor MossRoad's Avatar
    Join Date
    Aug 2001
    Posts
    20,718
    South Bend, Indiana (near)
    Power Trac PT425 2001 Model Year
    I'd look at some of the commercial ones available and copy their design.
    (I ain't too original or creative, if you haven't noticed over the years ).
    I was always interested in the D.R. brand for smaller tractors. Perhaps a good place to start looking.
    MossRoad
    Click On My Little Tractor
    To See Pictures And Videos
    Of It In Action!!!
  4. #4
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    5,900
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    Do some searching, lots of threads on this, bought and home built. Build it as heavy as your tractor will handle and don't get greedy with the width. You are better off with a heavy 6 foot unit than a lighter 7' unit. You are best off with no less than 150lbs per foot of width. Heavier is better, but your tractor will only handle so much.
    Good luck
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  5. #5
    Join Date
    Jul 2006
    Posts
    3,439
    PowerTrac 1850
    Thanks everyone. I have my design for the most part (Still struggling on wether to angle the cutting blades or have them run parallel, no one seems to have the straight answer on that).
    But the killer for me is push or pull. Box blade will not work in push mode, I would love it if the landscape would, but I think that if it gets hung on something I am going to push over top of it. Probably better to pull it but this will make for a miserable mile of road I have to grade.
    Carl
  6. #6
    Gold Member Clumber's Avatar
    Join Date
    Sep 2010
    Posts
    322
    Northern Virginia
    PT425 (Dec 2010)
    I have a similar situation with a mile long private road of blue crusher mix stone. I have used my PT 425 with a box blade on a short section of the road with good result, but it is slow and pulling the blade works best. The road has deep ruts due to water runoff.
    I am thinking about buying a Power-trac Power Rake attachment for another purpose, but I'm thinking that the power rake might be a faster solution to smoothing out the deep ruts on the road. The rake can be operated in push-mode. However, a final pass with the box blade may still be necessary.
    Anybody here ever use a power rake like this?
    I married me a hippy, ran away with a stringy haired blond,
    Now we're both old and happy, fishing on our own Golden Pond. -- Merle Haggard
    PT 425 (Dec 2010), Blade, Snow Blower, Sweeper, Spreader, LMB, 4n1, Small Bucket/Teeth, Utility Grapple, Brush Cutter, Box Blade, Mini Hoe/Thumb, Forks, Power Dumper
  7. #7
    Elite Member
    Advertiser
    Join Date
    Mar 2005
    Posts
    5,900
    Quote Originally Posted by woodlandfarms View Post
    Carl
    As far as I know of, every commercially built unit has angled blades. The home built units are common to have the blades straight. Why do you think that may be? It sure wouldn't be because it is easier to build with the blades straight, now is it?
    Brian
  8. #8
    Join Date
    Mar 2007
    Posts
    965
    Bay Area, CA
    Power Trac PT1445
    Dear Carl,
    Based on my experience, I think that you want the cutting blades in a multiple chevron design <<>>. This will redistribute and level the material the best. As suggested by MtnViewRanch, keep it heavy enough to dig in. To break up bad ruts or potholes, you may need to scarify a bad section first before using the land plane.
    Finally, a little clay or fine rock dust will go a long way to permanently keeping your roadbed solid, and keep potholes from reforming. Many people make the mistake of filling the potholes only with larger aggregate, which then creates a holding space for water that vehicles dislodge, carrying the binder (rock dust/fines/clay) out of the roadbed, making the pothole worse.
    Have fun.
    All the best,
    Peter
    Carl
  9. #9
    bcp
    bcp is online now
    Join Date
    Jul 2009
    Posts
    2,245
    SW WA
    Kubota BX2360
    If the commercial ones were built both ways, and both types stocked by dealers, I think most buyers would buy the angled ones, thinking it will build a crown better. But some users of angled ones say there is almost no sideways movement of material.
    Others build straight ones because they intend to use it for leveling and don't want sideways movement of material.
    Bruce
  10. #10
    Elite Member
    Advertiser
    Join Date
    Mar 2005
    Posts
    5,900
    Quote Originally Posted by bcp View Post
    Bruce
    For my uses anyway, I agree with this statement 100%. If I were to build a crown on my roads based solely on the sideways material movement, I doubt that it could even be done, but at best it would take thousands of passes and that is no exaggeration.
    Brian
Similar Threads
  1. What size Land Plane for Kubota L3940
    By CCOUGHRAN1 in forum Attachments
    Last Post: 06-14-2011, 12:28 PM
  2. Questions before my M6040 Purchase
    By air19 in forum Kubota Buying/Pricing
    Last Post: 09-01-2007, 09:54 PM
  3. Rake Used LP 25-84 landscape rake
    By computerboy in forum Attachments
    Last Post: 04-19-2006, 05:03 PM
  4. Tractor Questions
    By SKOALMAN in forum Kioti Owning/Operating
    Last Post: 02-13-2003, 06:28 PM
  5. Rake Leveling soil with a landscape rake
    By Mosey in forum Attachments
    Last Post: 12-06-2002, 12:39 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
