Results 1 to 3 of 3
06-28-2012, 02:02 PM #1Bronze Member
- Join Date
- Dec 2001
- Posts
- 61
- Location
- Hartland VT
- Tractor
- Power Trac PT-425 (new June 26, 2011)
Mower angle stop bolt PT-425
As discussed elsewhere, when you pick up a mower (finish or brush), even with attachment plate rolled all the way back, the mower deck angles down such that the front wheels of the mower touch and the rear of the deck is like a foot off the ground. This makes hacking off the top of tall weeds (or my case the regrowth of honeysuckle shoots after having cut down the bush with a chainsaw) impossible.
So like others in this forum I entertained the idea of moving the front stop bolt to level the deck, but didn't like the idea of drilling holes in the mower attachment bar. So instead I drilled a hole in a small length of 1-1/2" angle iron and used the existing front bolt to attach it.
This small bit of distance levels the mower deck plus the angle iron provides more surface area against the mower attachment bar. Bonus!
As I was mowing today with the attachment plate angled in the "middle" I didn't notice any loss of rotation. If that becomes a problem, I would just roll the attachment plate to give more play in that direction (e.g. mowing up or down a ditch).
I am still considering drilling a hole through the hole that PowerTrac drilled in the center of the mower attachment bar and inserting a hitch pin to make cleaning under the deck easier. Though there really isn't much build up under there, so not critical.
06-28-2012 02:02 PM # ADS
06-28-2012, 04:27 PM #2
Re: Mower angle stop bolt PT-425
Congrats, that's a clever fix. I never liked that I could see the blades when I had to lift the mower even a small amount. Let us know if you have any restriction going up and down a steep embankment in float mode.
I married me a hippy, ran away with a stringy haired blond,
Now we're both old and happy, fishing on our own Golden Pond. -- Merle Haggard
PT 425 (Dec 2010), Blade, Snow Blower, Sweeper, Spreader, LMB, 4n1, Small Bucket/Teeth, Utility Grapple, Brush Cutter, Box Blade, Mini Hoe/Thumb, Forks, Power Dumper
06-30-2012, 10:34 PM #3
Similar Threads
JD 425 won't stop moving when forward pedal released
By billmuis in forum John Deere Lawn & GardenReplies: 17Last Post: 06-27-2011, 01:23 PM -
PEDAL STOP BOLT
By dodge man in forum Kubota Owning/OperatingReplies: 10Last Post: 12-04-2008, 12:06 PM -
Why has Sears stop making this riding mower?
By JohnBoy45 in forum Craftsman / SearsReplies: 5Last Post: 02-10-2006, 12:40 PM -
Grading 425 Brush Mower blade bolt failure.
By Carpenter in forum Power TracReplies: 3Last Post: 05-29-2005, 11:33 PM -
Mowing Will finish mower on 425 double as brush mower?
By RickeyL in forum Power TracReplies: 6Last Post: 09-07-2003, 11:12 AM
