Results 1 to 6 of 6
  1. #1
    Join Date
    May 2012
    Posts
    119
    Lake City, Michigan
    CaseIH 685 & JD 3320
    Default POWER TRAC TREE SHEAR
    Hello;
    I need input and opinions before I jump off the deep end. I am seriously considering purchasing a PT model Q3416 10 ton tree shear.
    It would be used on a John Deere 3320 with 300 CX loader. It will be used with a boom pole extension. Maybe 10 feet long. I figured if weight was an issue with it that far out I would attach a support chain to the pole near the shear and to a hook on top of the bucket. That brings up another question. Is mounting it to the bottom of the bucket o.k. or should the bucket be removed and mount to the loader frame?
    I've been on the hunt for a shear for about two weeks. During that time somewhere I heard a that shear with two cutting blades coming together was no good. That it should have only one cutting blade and a slot on the opposite side for the blade to go into to provide a total cut and not dull the blades.
    I'm ready and anxious for any info you will provide.
    Thanks, nicholas
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: POWER TRAC TREE SHEAR
    If you want to save money and build something very simple, then look at these pictures.
    One 3/4 in cutting blade closing on another 3/4 flat steel , using an 8 in cyl , 2 in bore, and is on a long boom.
    In the last picture, there is a guide to help keep the limb in the cutter during the cut, and keep the blade straight.
    Attached Thumbnails Attached Thumbnails POWER  TRAC  TREE  SHEAR-pt-1445-001-jpg   POWER  TRAC  TREE  SHEAR-pt-1445-004-jpg   POWER  TRAC  TREE  SHEAR-pt-1445-002-jpg   POWER  TRAC  TREE  SHEAR-shear-like-mine-jpg
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Here are some more pictures. of tree cutters.
    Last picture is a hyd chainsaw. Mount it on a boom and do some high tree work.
    http://youtu.be/nFt6YsTcEck
    http://youtu.be/nCAzSMUUw6k
    http://youtu.be/9NiXeYqR30k
    http://youtu.be/oTL1LYFlgKc
    Attached Thumbnails Attached Thumbnails POWER  TRAC  TREE  SHEAR-tree1s-jpg   POWER  TRAC  TREE  SHEAR-tree2-jpg   POWER  TRAC  TREE  SHEAR-treeshear2-jpg   POWER  TRAC  TREE  SHEAR-hydracutter_closeup-jpg
    J.J.
    Git er done.
  4. #4
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    You could also build yourself a mini log splitter and mount it on a boom.
    Similar to this.
    Skid Steer Tree Trimmer and Wood Splitter - YouTube
    J.J.
    Git er done.
  5. #5
    Gold Member Clumber's Avatar
    Join Date
    Sep 2010
    Posts
    358
    Northern Virginia
    PT425 (Dec 2010)
    See the Used-PT page on the power-trac site. There is tree-shear for sale.
    Used Power Tracs
    Contact:
    eyedoctor99@yahoo.com
    call: 276-963-7400
    I married me a hippy, ran away with a stringy haired blond,
    Now we're both old and happy, fishing on our own Golden Pond. -- Merle Haggard
    PT 425 (Dec 2010), Blade, Snow Blower, Sweeper, Spreader, LMB, 4n1, Small Bucket/Teeth, Utility Grapple, Brush Cutter, Box Blade, Mini Hoe/Thumb, Forks, Power Dumper
  6. #6
    Veteran Member Rara Avis's Avatar
    Join Date
    Oct 2006
    Posts
    2,226
    VT, ND & OH
    John Deere
    Quote Originally Posted by pane056 View Post
    Hello;
    Thanks, nicholas
    Did you look at a Limbinator?
    Limbinator Saw
Similar Threads
  1. Tree Shear
    By mmorisoli in forum Kubota Owning/Operating
    Last Post: 10-07-2014, 09:45 AM
  2. Tree Shear
    By arkkid in forum Attachments
    Last Post: 12-10-2010, 01:47 PM
  3. Tree Shear
    By TRUKFXR in forum Power Trac
    Last Post: 07-20-2009, 01:49 AM
  4. Tree Shear
    By jfh28 in forum Power Trac
    Last Post: 03-14-2006, 09:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
