Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1
    Silver Member coolconnection's Avatar
    Join Date
    Oct 2008
    Posts
    243
    Ohio
    PT 425
    Default
    Pallet forks don't get much use and to me seems like they would work better than using the bucket. Any ideas on designs?
  2. #2
    Super Member woodlandfarms's Avatar
    Join Date
    Jul 2006
    Posts
    5,592
    Los Angeles / SW Washington
    PowerTrac 1850, Kubota RTV x900
    Default Re: Anyone make a grapple out of power tracs fixed pallet forks?
    It would be a simple and not too grapply, but I have seen it done with other tractors. I personally prefer more tines and I think you will to. I would rather put a grapple on a bucket.
    you can use your pallets for digging trenches...
    Power-Trac 1850, grapple, hoe, 90" mower, 72" box blade
  3. #3
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Quote Originally Posted by coolconnection View Post
    Here are a few designs.
    Attached Thumbnails Attached Thumbnails Anyone make a grapple out of power tracs fixed pallet forks?-015c_1-jpg   Anyone make a grapple out of power tracs fixed pallet forks?-1-arm-grapple-pallet-fork   Anyone make a grapple out of power tracs fixed pallet forks?-rear-corner-view1327685750-jpg   Anyone make a grapple out of power tracs fixed pallet forks?-log-grapple-loader-forks66-jpg   Anyone make a grapple out of power tracs fixed pallet forks?-grapple-fork-jpg
    Anyone make a grapple out of power tracs fixed pallet forks?-grapple12-jpg   Anyone make a grapple out of power tracs fixed pallet forks?-fork-grapple1-jpg   Anyone make a grapple out of power tracs fixed pallet forks?-27702_lg-jpg   Anyone make a grapple out of power tracs fixed pallet forks?-336grapple1-jpg
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  4. #4
    Join Date
    Oct 2008
    Posts
    243
    Ohio
    PT 425
    Default
    Wow, thanks. This is what I was looking for.
  5. #5
    Join Date
    Jul 2003
    Posts
    172
    Watertown, SD
    PT-422
    I had a local welder build a quick attach plate and the grapple. I used the hydraulic cylinder from my snow blade. I attached it to an old set of manure forks from another small tractor. The grapple on my fork is heavier than I like. Another option would be to attach it to the large bucket or the pallet forks would work for large stuff.
    Attached Thumbnails Attached Thumbnails Anyone make a grapple out of power tracs fixed pallet forks?-img_0089-jpg   Anyone make a grapple out of power tracs fixed pallet forks?-img_0093-jpg
  6. #6
    Join Date
    Oct 2008
    Posts
    243
    Ohio
    PT 425
    DHS thanks for the pics. I am thinking something semi-permanent for my pallet forks. Most of the time they just sit there so if I can utilize them for another purpose that would work for me. I like the bucket grapple idea but I use my bucket a lot for other things and I can just see the small trees and limbs just flopping around in there. DHS I hope you don't mind but I might use some of your ideas on my little project.
  7. #7
    Elite Member
    Join Date
    Jun 2006
    Posts
    2,988
    West Cascades, Washington State USA
    PT 422
    Nice project! Thanks for the picts.
  8. #8
    Join Date
    Jul 2003
    Posts
    172
    Watertown, SD
    PT-422
    I used others ideas when I had mine built. My local welder built mine for about $150. It is easily removed with a couple bolts. I have tines on mine for sifting and removing large rocks from my beach. This is the url of what you might be looking for. Looks very much like mine. I have pallet forks and the top of the quick attach plate is not very wide and will require beefing up to attach the grapple but it should work fine.
    New bucket Thumb grapple for Skid steer loader tractor | eBay
    That said if Power Trac's current grapple had been available when I built mine I probably would have purchased it.
  9. #9
    Join Date
    Oct 2008
    Posts
    243
    Ohio
    PT 425
    Anyone know what size of hydraulic cylinder will work for a PT 425. PSI and so forth. When I get a final design done I know to look for length of cylinder but what should I look for in shaft diameter. I really have been thinking on this idea lately especially since all these spring storms and I see that I will need to have some of my big trees close to the house topped.
  10. #10
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Shaft size should be about 1/2 of bore diameter.
    J.J.
    Git er done.
Similar Threads
  1. Slide on grapple for pallet forks
    By tomd999 in forum Attachments
    Last Post: 08-12-2012, 08:05 PM
  2. pallet forks or grapple for boulders?
    By Builder in forum Construction Equipment
    Last Post: 07-16-2011, 05:06 PM
  3. pallet forks with grapple?
    By countrybumpkin in forum Attachments
    Last Post: 04-02-2010, 07:08 AM
  4. just bought stump grapple and pallet forks!
    By Skerby in forum New Holland Owning/Operating
    Last Post: 05-28-2008, 12:23 PM
  5. Forks Does anyone make 3 Point Forks for pallet lifting
    By reberly in forum Attachments
    Last Post: 06-26-2004, 12:06 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
