Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Silver Member coolconnection's Avatar
    Join Date
    Oct 2008
    Posts
    232
    Ohio
    PT 425
    Default 60 inch mower blades no longer made.
    Well just getting my attachments put away and ready for next spring and took off the mower blades on my 60" deck for the pt 425 to sharpen and found that this was probably the last year for them. I am kind of hard on them, I mow sticks and other debris thats in my way. Well I looked up the blade number - Oregon 90-125 and went to their web site and guess what they are no longer made. I even wrote them and they wrote back, "We do not have a direct replacement for the 90-125." So if you need a new blade and use this type you can find some on eBay and I am going to purchase some otherwise it might be difficult later on to find anything. This blade number has a 5/8 inch drop in them and works well for me and it also came on the deck. What I wanted was some Gator blades for my deck so if anyone knows where I can find some suitable for my deck I would be grateful. Just thought you might like to know.
  2. #2
    Silver Member frischtr's Avatar
    Join Date
    Feb 2010
    Posts
    151
    Harford County, MD
    PT-425
    Default Re: 60 inch mower blades no longer made.
    I have several sets of these: 21" X 3/8" hole Offset Universal Blade | Lawn Mower Parts | MFG Supply
    Not Oregon, but a direct replacement. They work great...
    2010 PT-425 - 60" finish mower, 60" blade, 45" grapple bucket, 10cu' lmb
    2004 Dodge Ram 2500 SLT 4x4 5.9L Cummins HPCR Turbo Diesel QCLB NV5600 6-speed manual 4.10s
    IBEW Local #24
  3. #3
    Join Date
    Oct 2008
    Posts
    232
    Ohio
    PT 425
    Thank frischtr, I checked that sight out and that is a really good price for these.
  4. #4
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    These blades are what I use on my Dixie Chopper with 60 in deck.
    Jacks Small Engines-Dixie Chopper Gator Blades
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  5. #5
    Member
    Join Date
    May 2010
    Posts
    32
    Maryland
    Wheelhorse/Toro 520Xi MF GC1715
    Resurrecting old thread :-)
    I have a 520XI (1999) with a 60" deck and in need of good blades for this season. The ones on there now (3 of them) are 20.25" long and about 3" wide. Can I go shorter/narrower than what is on there?
    Any advice for this machine? I use side discharge so mulching blades would be nice. Thanks again!
    Semper Fi
  6. #6
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Most blades are designed to overlap .
    If you go short on the blade length, you might leave sprigs/rows, etc.
    J.J.
    Git er done.
  7. #7
    Platinum Member Raw Dodge's Avatar
    Join Date
    Apr 2009
    Posts
    625
    Orange County,NY
    Ventrac 4231,Dixie Chopper XXWD5000
    Default
    If you really need a set, the center hole diameter is the most important aspect. .you can always grind a little off the length to make the very common 20.5" fit, then rebalance the blade. .hopefully it's a common size like 1/2" or 5/8" center hole..
    Cat 246 SS,Homemade 35T log splitter,2004 Ventrac 4231G various attachments...2005 Dixie chopper XXWD5000, 2001 Dixie Chopper XW2500-60
  8. #8
    Epic Contributor MossRoad's Avatar
    Join Date
    Aug 2001
    Posts
    33,801
    South Bend, Indiana (near)
    Power Trac PT425 2001 Model Year
    Quote Originally Posted by Usmc68 View Post
    Semper Fi
    This is the Power Trac forum... You might be better off posting this in a more brand-specific forum suited to your machine.
    MossRoad
    Click On My Little Tractor
    To See Pictures And Videos
    Of It In Action!!!
  9. #9
    Join Date
    Dec 2001
    Posts
    92
    Hartland VT
    Power Trac PT-425 (2011)
    I just bought 6 of these, and they are indeed have the same lift/blade profile and the correct size hole. The only thing is you have to cut off about 1/8" off each end or they will hit each other. To do this I paired a new and an old blade together with the bolt running through both to align them, then clamped in the vise before cutting off the excess using an angle grinder with metal cutoff disk. Then removed from vise then used my stationary grinder to balance (I use that little balancing cone thing).
    Quote Originally Posted by frischtr View Post
  10. #10
    Join Date
    Mar 2007
    Posts
    1,533
    Bay Area, CA
    Power Trac PT1445
    Little balancing cone thing?
    Got a picture?
    Thanks!
    Peter
Similar Threads
  1. Mid-Mount Mower 54 inch or 60 inch Mid Mount Mower
    By phyxer in forum Attachments
    Last Post: 03-04-2009, 11:37 AM
  2. The T273 TLB is no longer made.
    By Grut in forum TYM Owning/Operating
    Last Post: 11-02-2008, 06:37 AM
  3. Box Scraper 42 inch box blades - who else makes them?
    By awl51 in forum Attachments
    Last Post: 03-14-2008, 11:56 PM
  4. Mowing width of 62 Inch and 54 inch mower
    By CFHartman in forum John Deere Owning/Operating
    Last Post: 06-08-2004, 10:34 AM
  5. Do You Need Replacement Blades for a 54 inch Deck?
    By NY_Yankees_Fan in forum Kubota Owning/Operating
    Last Post: 05-04-2003, 02:30 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
