Results 31 to 40 of 40
12-24-2012, 11:05 PM #31Veteran Member
- Join Date
- Jun 2006
- Posts
- 1,279
- Location
- West Cascades Washington State
- Tractor
- PT 422
Re: PT Steering Project
Interesting project!
I seem to be turning and operating the FEL almost constantly. I tried out the spinner but kept catching my fingers on it and jamming them, I'm kind of a klutz, and didn't really seem to need it.
12-24-2012 11:05 PM # ADS
12-25-2012, 09:05 AM #32
I married me a hippy, ran away with a stringy haired blond,
Now we're both old and happy, fishing on our own Golden Pond. -- Merle Haggard
PT 425 (Dec 2010), Blade, Snow Blower, Sweeper, Spreader, LMB, 4n1, Small Bucket/Teeth, Utility Grapple, Brush Cutter, Box Blade, Mini Hoe/Thumb, Forks, Power Dumper
12-25-2012, 11:04 AM #33Veteran Member
- Join Date
- Jun 2006
- Posts
- 1,279
- Location
- Tractor
- PT 422
12-26-2012, 12:15 AM #34Epic Contributor
- Join Date
- Aug 2001
- Posts
- 20,761
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
If you do not get a lever valve with a power beyond port built into it, you will have to find another way to feed power to the loader valve. That will require a TEE fitting (to split the flow to both the steering lever valve and the loader valve), two hoses to feed each valve from that tee, another tee to split the return line and two more hoses to route return fluid from the new lever valve and loader valve back to the tee,
If you get a steering lever valve with a built in power beyond port, you will need one hose to feed the loader valve.... that's it. It equates to two tees and four hoses with 10 fittings VS one hose and two fittings. Much much simpler and less expensive to get your new steering lever valve with a built in power beyond port, in my opinion.
Someone else chime in here if I'm missing something please.
12-26-2012, 03:12 PM #35Veteran Member
- Join Date
- Dec 2006
- Posts
- 1,534
- Location
- South of Rochester, NY
- Tractor
- Power Trac 1850, NH 2120
The only problem I have with the spinner knob is that the side opening for a button cuff can catch on it when steering normally. So I have to be a little careful when wearing long sleeves which is most of the time when doing tractor work. It is not an issue in cold weather when wearing a coat.
KenPT1850, mini hoe, grapple, knuckle boom, stump grinder, brush hog
http://www.usadiscountgenerators.com...T1850Home.html
12-26-2012, 03:52 PM #36
12-26-2012, 04:33 PM #37Epic Contributor
- Join Date
- Aug 2001
- Posts
- 20,761
- Location
- Tractor
12-26-2012, 06:45 PM #38Platinum Member
- Join Date
- Jan 2004
- Posts
- 685
- Location
- east TN
- Tractor
- Power-trac 422 January 2003 model
I am in complete agreement that a power beyond valve is needed or at least be best. But just for the “fun of it” what would happen or not happen if say I just put a cheap log splitter valve on it with no power beyond, no detent, just a straight 3 position 4 way valve. Pressure would flow straight through TO the lift, tilt, quick attach valve when the cheap simple valve is in the neutral position you know (open center). Now it could mess with relief settings is one thing. By answering this it will help us understand power beyond. Curious to know why it would not at least half way try to function. Or what might tear up?
Is power beyond a check valve? Is it a regulator? It would be good to know what is going on when this valve works. Maybe as I research I will be able to answer my own question. But right now I do not have a complete understanding.
I will go ahead and ad this but do not concentrate on this and forget about the above concern.
Take a rope and tie it around you waist. Now take your left arm and stick it down through the rope.
Now leave it there and go out and design a steering system for that condition.
12-26-2012, 09:43 PM #39
12-26-2012, 10:01 PM #40Epic Contributor
- Join Date
- Aug 2001
- Posts
- 20,761
- Location
- Tractor
We have come to the point where further education is needed.
I have referred to this in the past, and have re-read parts of it over the years. It is the U.S. Army Field Manual FM 5-499 for hydraulics. It is great reading for all Power Trac owners and will really help anyone that has any questions about hydraulic theory.
I would attach it here, but it is 1.2M in size, so here is a link to it. Download it to your PC for safe keeping.
http://www.derijcke.com/dl/manual.pdf
Read chapter 2 for a starter.
Similar Threads
L3750 Kubota Steering Shaft Spins and Tractor Steering Does Not Move
By Joe Joseph in forum Parts/RepairsReplies: 3Last Post: 07-04-2012, 12:09 PM -
Power Steering & FEL on Yanmar F16 project
By jimmer2880 in forum CustomizationReplies: 75Last Post: 09-05-2011, 08:42 AM -
a deal on power steering project
By Kernopelli in forum Build-It YourselfReplies: 2Last Post: 08-14-2011, 10:41 PM -
Looking for a Power Steering kit for older L2550DT w/ manual steering
By JTPass in forum Kubota Owning/OperatingReplies: 1Last Post: 06-29-2009, 04:13 PM -
Satoh Beaver need a Steering Box,Steering Wheel
By kentteri in forum Mitsubishi/SatohReplies: 2Last Post: 04-19-2008, 12:16 PM
