Results 1 to 5 of 5
02-09-2013, 10:11 PM #1
- Join Date
- Jan 2004
- Posts
- 623
- Location
- NW Tasmania, Australia
- Tractor
- Kubota F-2880
Flail or Mulcher mower head?
Have not been on the site much lately, but wonder if anyone used the PT Flail mower on 1845 or -50? Or any flail or mulcher-mower on any PT for that matter??
Cheers, RipKubota F2880 w/60" Front Mower
02-10-2013, 06:40 PM #2
- Join Date
- Sep 2003
- Posts
- 18,924
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
Re: Flail or Mulcher mower head?
I have a 72 flail mower that I use on my 1445.
Is there a particular question.J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done.
02-10-2013, 08:07 PM #3
- Join Date
- Jan 2004
- Posts
- 623
- Location
- Tractor
- Kubota F-2880
Hi J J,
Do you have the PT flail mower or did you adapt something else? How well does it work for you?
I have an 1845 in Colorado with all the mountain, tree and snow tools, but are relocating to where I have serious grass to deal with instead. Love the PT, but not sure if I want to go to all the effort to sell the bits & pieces I won't need, move the rest and buy a flail for it......but it is a possibility.
Notice you also have a full-size kubota.......one of my other options for grass is a used ex-municipal 2009 Kubota 4wd F-2880 with 60" deck......may be good enough as is to do all my 4 acres of grass or can be fitted with a flail for the real rough stuff.....should handle the slopes here also.
If I got the F2880, would be looking to buy or make a front carry-all to replace the mower deck just to move stuff around.....you seen something along those lines??
Cheers, RipLast edited by Rip; 02-10-2013 at 08:10 PM. Reason: Added question
02-11-2013, 09:52 AM #4
- Join Date
- Sep 2003
- Posts
- 18,924
- Location
- JACKSONVILLE, FL
- Tractor
I have the PT flail. I only have about 13 GPM on my PTO. You probably have more, which would give the flail rotor a faster speed.
I did make an adapter to connect it to my Case 1845c skidsteer which has more GPM's
Remove the deck F2880 and make or modify something like this.
http://www.lulusoso.com/products/Use...c-Stacker.htmlLast edited by J_J; 02-11-2013 at 01:23 PM.
J.J.
Git er done.
02-11-2013, 04:54 PM #5
- Join Date
- Jan 2004
- Posts
- 623
- Location
- Tractor
- Kubota F-2880
Thanks for the info on your flail......my 1845 is only about 15 GPM, but PT lists it as being compatible. Guess you are satisfied enough with how the flail itself works though.
As for the kubota F2880 (just like the current F3080), I have looked more at the JohnnyBucket and could rig up something like it with a used bucket of similar size.....could rig up some small forks also......would not need to handle full-size forks or pallets.Kubota F2880 w/60" Front Mower
Similar Threads
Balancing mulcher head??
By ALittleDirtWontHurt in forum Land Clearing EquipmentReplies: 4Last Post: 01-02-2013, 08:59 PM -
New mulcher head
By Texas jerry in forum Land Clearing EquipmentReplies: 22Last Post: 12-31-2011, 08:27 PM -
Buying Advice forestry mulcher head
By greensmith in forum Buying/Pricing/ComparisonsReplies: 3Last Post: 12-03-2011, 07:46 PM -
Mulcher or Flail Mower 4 Track Loader...?
By budcampo in forum AttachmentsReplies: 10Last Post: 02-03-2011, 12:27 PM -
Flail Mower Flail mower versus mulcher?
By Redfox in forum AttachmentsReplies: 10Last Post: 05-05-2009, 09:40 AM
